Right side crankcase cover oil plug
9 replies to this topic
  • MattB1969
Posted 07 July 2008 - 05:32 AM
I may have stripped some threads on the rscc oil drain plug (female part). Can this be re-threaded? Anyone have a fix for this? I took the crush washer off the plug and it seams to hold Ok......
any ideas on cost/ better yet anyone have one for sale in case I need to replace the darn thing? :crazy:
Matt
  • E.Marquez
Posted 07 July 2008 - 05:48 AM
What plug??? the drain plug is on the bottom of the case... Are you talking about the oil galley plug below the oil filter housing?
If so,, that is not removed unless your trying to hook up an oil pressure tester for servicing or repair issues.
Not worth tiring to fix,,but not cheap to replace at $145 from ronayers.
  • E.Marquez
Posted 07 July 2008 - 05:50 AM
I suppose, as long as the cover is junk anyway... I'd be tempted to fix that galley plug in place permanently.. JB weld or the like.
That plug never needed to be removed as a routine.. and if the day comes that your having a need, then consider the cover to be part of the cost of that repair.
  • MattB1969
Posted 07 July 2008 - 05:52 AM
Hey thanks for the info.......
  • E.Marquez
Posted 07 July 2008 - 05:55 AM
We are talking about this part yes #92066 ?
Attached File  case covers.bmp   274.99K   99 downloads
  • MattB1969
Posted 07 July 2008 - 06:15 AM
[attach]8252[/attach]
It's the plug below the oil filter......that pic looks like the left side...
  • E.Marquez
Posted 07 July 2008 - 06:24 AM
Both left and right side are shown in that picture.. the part # I gave is the oil galley plug below the oil filter.
So, everything above stands... No need to remove it, if you can get the plug in, and "glued" in place... your done.:thumbsup:
  • MattB1969
Posted 07 July 2008 - 06:28 AM
Yea, don't know what I was thinkin....anyway, its tight enough , Lesson is don't drink and do an oil change.....lol :ride:
  • rustyknife
Posted 07 July 2008 - 09:34 AM
Can easily be rethreaded.. The kits cost rougly 45 bucks each size though and if you dont wanna buy the tool, a machine shop can do er for 15-20 bucks probly
  • E.Marquez
Posted 07 July 2008 - 09:56 AM
Well maybe. for one, the full kit to install a large threaded insert like this one would be more like $65 or so...
The case cover is cast, and there is very little material in that area.
Adding a threaded insert... means drilling the current threaded hole to an over size... that would leave VERY little material at the case are surrounding the galley plug.
1/2 a dozen of one, 6 of the other. That particular plug was not designed to be removed and installed at the user level.... so, for once, the use of JB weld of the like actually makes sense to me...
To each his own... I use a lot of threaded inserts, Timecert and helicoil.. just do not see the reason for it in this case.
