What The! Valve cover removal
15 replies to this topic
  • neevothespaniel
Posted July 06, 2008 - 03:13 AM
For those that do their own maintenance please enlighten me.
Coming off a 05 YZ checking valves clearances was easy, remove tank and valve cover. Now I have migrated to an 08 WR I am struggling with the new Alu frame and valve cover access.
What I am doing at the moment is removing shrouds, tank, hot start, upper engine mount however I am having to force things a little more than I would like to get the valve cover off and getting it back on is even more worrying.
Can anyone give me the magic answer?
  • Frostbite
Posted July 06, 2008 - 03:34 AM
I've never removed the hot start, but everything else you mentioned. It is a very tight squeeze but the cover will slip out. You have to roll it around a bit and the top of the cover and the gasket on the bottom are touching bits as you work it out. I haven't found a magic contortion where there is actually clearance, but it will come out.
  • neevothespaniel
Posted July 06, 2008 - 03:58 AM
Sounds like you are in the same position as me. I can get the cover off but in some places I am really bending and squashing the rubber half circle gaskets on the gear shift side.
Stupid Alu frame, pity it rides so bloody well :thumbsup:
  • Frostbite
Posted July 06, 2008 - 06:52 AM
I had one more pain to deal with, at -30 the hoses and wiring harness are like steel. I had to use a steamer to soften them up to move them out of the way, and then try and get the cover out before they stiffened up again. I was cursing.
Posted July 06, 2008 - 07:18 AM
The cover comes off the easiest by taking it out the right side, which means that you'll need to break the adhesion of the cover gasket along the left side so that the half moons can lay over for clearance. The top mounts are all that I remove, other than the tank, of course.
  • MaxPower
Posted July 06, 2008 - 08:31 AM
[COLOR="Green"]YIKES![/COLOR]
  • SJMC_DON
Posted July 06, 2008 - 09:04 PM
I have had more luck leaving the gasket in place on the cyl head... the first time I did it I broke the gasket at the L/F corner trying to separate the cover and gasket because I think Yamaha used to much adhesive there... anyway, a new gasket and some trial and error and I have been able remove and replace the cover and gasket separately, or one at a time and it has proven to be much easier.
Like Frostbite I also do it without removing the hotstart... that little plastic nut is only going to take so many in and out cycles before it goes to sheet:prof:
  • neevothespaniel
Posted July 07, 2008 - 12:55 AM
Do you mean you take the cover off towards the kick starter?
Thanks for all the help. It looks like I might get a bit better with some more practice. I will leave the hotstart where it is from now on also.
Posted July 07, 2008 - 07:34 AM
Yes. It seems much more cooperative that way.
  • beezer
Posted July 07, 2008 - 08:54 AM
I'll sell the bike before I take the valve cover off again.
Lot's of filthy words came outta my mouth.
  • OUTERLIMITS
Posted July 07, 2008 - 09:04 AM
I guess it could be worse. There are guys with the new '08 Ktm 530's that can get the valve cover off no problem, but to actually make an adjustment requires dropping the engine or cutting off one of the tank mounts. This is because the bolt for the cam shaft retainer hits the tank mount that is over the engine before you can get the bolt out. Anyway, bike's in general are just getting harder to work on.
  • SJMC_DON
Posted July 07, 2008 - 09:15 AM
530 is shim and bucket? I love it :thumbsup:
  • OUTERLIMITS
Posted July 07, 2008 - 12:02 PM
530 is shim and bucket? I love it :cry:
It's a single cam and should have adjusters like the older model, but it does use shims for some reason. A lot of cursing on KTMTalk.com about this little design oversight. Most people are cutting part of the tank mount off and then using the piece cut off as a spacer :p. Almost dropped the $$'s for a 530, but glad I went with the WR and it's seemingly small issues so far. :thumbsup:
Posted July 07, 2008 - 01:40 PM
Damn! Sounds like working on cars for a living all over again. When the first front wheel drive Malibu came out, the procedure for removing the trans called for removing the the left motor mount bracket from the body. I had to get some clarification on that from GM, because it was welded in place. :thumbsup:
  • xrmarty
Posted July 07, 2008 - 06:41 PM
Ha! Ha! Ha! I thought I was the only one going crazy with this. At first, I really struggled with the cover. Then I figured out there is only one way it goes in and one way it comes out. As Grayracer said, it has to come out on the kick start side. Lift the cover ( on shifter side) as much as you can so that one side is up and the kickstarter side is somewhat lower. Then work it over to the kickstarter side by wigling it a bit. You may have to move some things out of the way like hoses or wiring. It's just like a puzzle piece. It goes in and out only one way.
  • neevothespaniel
Posted July 08, 2008 - 03:04 AM
Oh well I suppose its just the price we pay for such a great, reliable bike.
