06450 Fork Oil Level
10 replies to this topic
  • ivesy
Posted June 30, 2008 - 05:13 PM
Hi there, can anyone tell me what the oil level in the forks should be when measured from the top (with the spring out etc). The manual only states a volume but I have lost some oil through badly leaking seals and need to top it up after cleaning the seals out.
Cheers
Posted June 30, 2008 - 08:10 PM
The '06 is not set to a level, as the older forks are. Unless someone measures their oil level while they fill it, there's no way to know.
Also, you can't measure with the spring out, because with the spring removed, there's a hole in the bottom of the fork.
  • ivesy
Posted June 30, 2008 - 10:01 PM
Ooh I'm kinda stuffed then, I guess I'll have to empty one fork out and refill the outer to the right specs and see if I can measure the oil level accurately.
Cheers
  • nathanyzf426
Posted July 01, 2008 - 03:19 AM
dont know if this works for your bike but i normally get a precision ruler and measure 120mm from the top of the inner fork tube yours may be different whilst you are that far you may as well just put new seals in there its really an easy job do do it will only take you an hour max to do the both forks seem as you say they where leaking so bad the dirt may have put wear on the seals just an opinion cheers mate nathan
  • Ga426owner
Posted July 01, 2008 - 05:43 AM
To GreyRacers point it is difficult to tell but on the avg it is around 350cc
Posted July 01, 2008 - 06:46 AM
He knows the amount, but he wants to be able to measure the level and add only what he needs without pulling the forks.
And yes, Nathan, the '06 fork is completely different.
  • saca
Posted July 02, 2008 - 07:04 PM
145 ~ 148 mm (5.71 ~ 5.83 in)
From top of fully stretched
damper assem
Posted July 02, 2008 - 07:17 PM
damper assem
That is the inner cartridge pre-assembly levellevel. He is trying to find the level for the outer chamber.
  • flemingjim
Posted July 06, 2008 - 05:17 PM
I got the same issue, need to know the stock oil volume for the outer chamber (06 yz450F). I measured the inner level at 150 mm prior to seal/wiper replacement, but I believe the outer chamber is set by volume. I never got the owners mannual from my dealer, left over 06 in 07! I took a guess and tossed in 200cc an hour ago, looks like I'm 150cc short if
Ga426Owner is correct.
Posted July 06, 2008 - 05:40 PM
Another one who didn't look in Common Threads. Download a manual;
http://www.yamaha-mo...ice/manuals.jsp
The listed outer volume is 350cc. I run a little less, but I'm using a much different fluid.
The inners have to be filled, have all the air worked out, then they must be compressed fully and filled up to at least the listed level of 145mm from the top. Then, the base valve assembly is inserted as the rod is allowed to extend. Once the valve is screwed down, the rods are fully compressed to force out any excess oil, and that oil is dumped out before installing the cartridge. They can be under filled, but not over filled.
  • flemingjim
Posted July 06, 2008 - 07:59 PM
http://www.yamaha-mo....ce/manuals.jsp
Thanks, I must have missed it in Common Threads. I've been riding and working on my bikes for 42 years, but I'm kind of new to forums! Thanks again, great site! I got to go read the manual now, to see what else I might have messed up!
  • Hot  113 replies
  • On January 15, 2017
  • Hot  28 replies
  • Hot  50 replies
  • 10 replies
