'98 YZ400F Rear Sprocket Question
5 replies to this topic
  • parkwinesguy
Posted June 27, 2008 - 08:34 PM
Complete novice to riding, going to take a look at a '98 YZ400F that says only problem is broken rear sprocket. What might a new middle-of-the-road sprocket cost for this bike? I know you can pretty much spend as much as you want for parts but just a reasonably priced one?
Also, what problems to look for on this bike?
Thanks in advance,
  • Slinkyman16
Posted June 27, 2008 - 09:55 PM
if one is broken then i would replace both sprockets and the chain..
right now on motosport u can get a complete sunline kit for 116 shipped. or you can get something like a renthal kit for 139.. its really depends on how much u want..
  • parkwinesguy
Posted June 27, 2008 - 09:58 PM
Thanks Slinky. And how many teeth would you go for this bike? 49, 50?
  • Slinkyman16
Posted June 27, 2008 - 10:08 PM
im not sure.. ive never owned the 400.. but i would start out with stock gearing then change it depending on ur needs.
  • parkwinesguy
Posted June 27, 2008 - 10:25 PM
Okay, thanks for the advice.
  • DeeCee
Posted June 28, 2008 - 12:16 AM
I reccomend you establish what caused the sprocket to be broken. If it was too tight a chain check the rear hub because tight chains are known to cause broken rear hubs as well.
There is another thread running on this forum at present regarding buying a 400f and what to look for, check it out.
Basically if it is in good condition, and been regularly maintained, it should be OK. They have a good reputation for reliablity.
Good luck.
  • 9 replies
  • Hot  33 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  491 replies
