WR400 with carb off WR426/450 - will it work?
4 replies to this topic
  • KevB
Posted June 24, 2008 - 01:53 AM
Hi all,
I have a '99 WR400F with the Keihin carb that still has the AP linkage outside the carb chasis. In doing some routine maintenance, I noticed that the slide plate was cracked :p (luckily before it failed...). so now I want to know if a newer model carb can just be bolted on or do I have to stick with the one I have and get it repaired?
Thanks in advance.:thumbsup:
Kevin
  • KevB
Posted June 25, 2008 - 12:25 AM
Just bumping it to the top to get more attention.
  • turbohead
Posted June 25, 2008 - 11:53 AM
The newer carb works great, but an Edelbrock is even better for your bike.
  • KevB
Posted June 26, 2008 - 01:48 AM
Thanks for the confirmation... I presume Edelbrock is a "special order" from the USA...
  • turbohead
Posted June 26, 2008 - 03:20 AM
Yes, it is. But there are a few around in Europe as well if you look for a used carb. Otherwise, order from the US (it'll transform your bike in general and everything you know about starting it in particular).
