Will Other Years Plastics Fit 02 WR 400?
4 replies to this topic
  • chambers
Posted June 24, 2008 - 01:14 AM
Pretty much as the title. As they changed the WR to a 426 in 02 I am having problems finding plastics to fit the 02 400, will any of the earlier or later years fit without any problems?
  • KevB
Posted June 24, 2008 - 04:34 AM
From my limited experience, you should be OK with 426 plastics... not 450 though
  • Frostbite
Posted June 24, 2008 - 05:13 AM
The front fender of my 99 WR 400 is identical to the fender on my 07 WR 450, except for the faded color.
  • matt4x4
Posted June 24, 2008 - 05:24 AM
plastics will work from 98 to 02 interchangeably.
There is only one difference and that is on rad shrouds - some years have the bolt go through the plastic at the front lower corner at right angles to the plastic, where others the bolt goes through at a 45.
See pic below - plastic is molded for 45, but bolt goes through at 90 - still works.
You can also use YZF plastics, front fender is the same, rear fender needs a small corner dremelled out inside for the WR exhaust pipe to fit through.
45 degree molded plastic with 90 degree bolt:
Look just above the mudflap on the right side (straight up from shock) - that corner had to be dremelled off on my YZF fender:
  • chambers
Posted June 24, 2008 - 08:21 AM
Thanks mate, will get some ordered this weeked
