can't shift from 1st to 2nd gear
8 replies to this topic
  • saca
Posted June 23, 2008 - 06:39 PM
Hi! I can't shift from 1st to 2nd gear , but if I put it on the stand shifts fine.
N to 2nd and up is good but if I shift down to 1st and up to 2nd it is not working. Any help or advice appreciated. Thanks!My bike is a 06'YZ450F
  • fritzelman
Posted June 23, 2008 - 07:47 PM
With it running or shut off?
Check the oil for metal fragments?
My guess is your clutch is too tight for a simple fix, but I'm thinking it might be something with your shift cam.
  • saca
Posted June 23, 2008 - 08:03 PM
The clutch is like new , the oil was nice and clean, When I test it on the stand it was running.
Posted June 23, 2008 - 08:26 PM
Check the condition of the "stopper lever", item 21 on page 4-70 of the manual. The '06 uses a ball bearing on the end of the lever instead of teh more conventional roller, and some have fallen apart, causing a variety of problems.
  • matt4x4
Posted June 24, 2008 - 06:46 AM
this thing:
  • saca
Posted June 24, 2008 - 03:48 PM
Thanks!
  • saca
Posted June 26, 2008 - 06:13 PM
Hi! I did Check the stopper lever but it looks good. Any other advice?????
Posted June 26, 2008 - 08:24 PM
Well, as long as it's open, try shifting it and look for problems with the operation of the linkage. Remember to turn the main shaft to align the gears as you shift.
  • matt4x4
Posted June 27, 2008 - 03:50 AM
It may "look good", but did you remove it and see if it "works good"?
Could be a bent shift fork...
  • Hot  47 replies
  • Hot  79 replies
  • Hot  33 replies
