Bleeding rear brakes
2 replies to this topic
  • 660boy
Posted June 22, 2008 - 08:03 PM
I just put on a baja designs kit on my 06 wr 450 and I had to replace the banjo bolt on top the rear master cyl . I cant :thumbsup: get the brakes bleed. Any Info will help thanks
  • 04WR450man
Posted June 23, 2008 - 05:10 AM
I use a large syringe and back bleed them, works a treat :thumbsup:
  • partialperson
Posted June 23, 2008 - 05:23 AM
When replacing the banjo bolt, bleed it just like the caliper. Close the bleeder, pump the brake lever/pedal, hold, crack open banjo, release air, tighten banjo, release lever/pedal. If it gets really frustrating, try the backflush, or try the hanging caliper method, take caliper off & hang it from the roof so that all the air rises to the caliper overnight.
