Raising forks on 08 yz 450
5 replies to this topic
  • krzyaszwhiteboy
Posted June 20, 2008 - 07:56 PM
I have read a lot about raising the forks 5mm in the clamps to help with the push that I am feeling with my bike. I did that this afternoon but I am not sure if I did it right. It looks like my forks are too close to my handle bars. Do I just take the grove that is right at the top of my trees and move it up 5mm? Also I read about gray mooving the bars forward and higher. Do I need different trees or bar mounts to do this. I can't see how it can be done with the stock trees or mounts? sorry for the long post but thanks in advance for any help.
  • Family Man
Posted June 20, 2008 - 08:20 PM
try putting your bars at +1 on the bar guide as opposed the the stock 0. raise your forks to the first line its probley 1/4 inch from stock.
  • psmith85
Posted June 21, 2008 - 06:17 AM
You can move your forks up in the clamps until they almost hit the bars without any worry. Once they are moved up, you will find it hard to adjust the compression screw without a very narrow screw drivers. I moved my forks up and it helped with the steering issue, but once I got rid of that POS front tire I was good to go. $60.00 for a new tire is well worth the investment and check the TPS every ride.
Posted June 21, 2008 - 06:51 AM
The Throttle Position Sensor? :thumbsup:
  • krzyaszwhiteboy
Posted June 21, 2008 - 08:46 AM
When you say line are you talking about the groove, because there is only one groove. Now there are very fine lines that seem like they are there more for a texture than anything. Sorry for sounding so stupid but over the years I have learned so much about bikes and so little about suspension. I have been reading a lot of books about suspensions and everything just seems to contradict everything else. I want to become a suspension master.
Posted June 21, 2008 - 11:58 AM
Yes, he means the machined groove, and there are two of them, at 5 and 10mm.
  • Hot  50 replies
  • 0 replies
  • Hot  36 replies
  • On January 15, 2017
