re-jetted; now bog
6 replies to this topic
  • frankycottonrow
Posted June 20, 2008 - 05:12 PM
I just finished putting a 165 main in my 07 450 to go w/ my Dr. D system. I opened fuel screw up 2 turns. Now when I let it idle and crack open the throttle, it bogs down and dies. Any ideas? Thanks
  • Smitty0720
Posted June 20, 2008 - 06:40 PM
after intensive searching. I realized this is supposed to happen (to a degree) hopefully it will run fine when I get it going. Does a larger leak jet help any. Thanks :thumbsup:
  • Family Man
Posted June 20, 2008 - 08:35 PM
Try the oring mod in the jetting section. Does it respond the same way with the stock jetting, and or its warmed up? Can you notice it while you ride?
  • sacfelix
Posted June 20, 2008 - 10:29 PM
If you figure it out please post
  • psmith85
Posted June 21, 2008 - 06:13 AM
Did it do this before you made the changes? If Not, then you can try things one at a time. Reset the fuel screw and retry, reinstall old pipe and retry etc until you find the issue.
I would not be overly concerned with this doing it at idle. I am more concerned about how it runs on the track.
  • Smokeslider
Posted June 21, 2008 - 01:52 PM
I would start with the fuel screw. Try going either way with it and see if it clears things up a bit, usually this seems to be the cause if all other jetting is close.
  • BBrown626
Posted June 21, 2008 - 02:39 PM
On the stand or after riding for at least 10 minutes? On the stand does not count. Follow the sticky on the jetting forum for setting the fuel screw. Do the o-ring mod and use a leak jet smaller than stock (40?).
