Stalling my 08 YZ450?
5 replies to this topic
  • racerdale
Posted June 20, 2008 - 07:11 AM
I race harescrambles and run the pro-class.I am having trouble stalling the bike on square edged bumps and sometimes into corners.I have been racing a two stroke for years and been on this 450 for about 8 months.Is this just me getting use to it,or is there something I can do to help problem?I tried a rekluse and was still stalling the bike.A friend says I am running to high a gear and it is loading up on me.Any help would be greatly appreciated.The bike is completely stock.Thanks
  • krackhead
Posted June 20, 2008 - 07:14 AM
Its probably a combo of jetting being off and running to high of a gear in the corner. My 08 is dialed in with jetting and it never stalls unless I do something stupid. But I am higher elevation so my specs wont help you.
  • llamaface
Posted June 20, 2008 - 08:04 AM
I have similar issues with my 4-stroke, which I blame on me being a spaz that mostly rides 2-strokes. If you're stalling with a rekluse tho, something is wrong and you need to fix it. Turning the idle up slightly helps me, as does pulling in the clutch coming into corners when I'm hard on the rear brake.
  • krackhead
Posted June 20, 2008 - 08:16 AM
this could be opinion, but at the MX class I took the pros said they would remove rear breaks if we used them. 80% of breaking is front 15% is engine, 5% rear. I have always been in the habit of using my front, I really struggle trying to use my rear.
Posted June 20, 2008 - 08:59 AM
You're brake stalling, by the sound of it, but as llama pointed out, that shouldn't be happening with a Rekluse.
But, two things that contribute to it are low idle speed and rich idle mixture. Low idle speed is obvious enough. But just as a lean mix makes the idle "hang", excessive richness makes the engine stumble when the throttle is chopped. Add a little in there, and you're parked. If you went with a fat pilot to eliminate all traces of decel pop, or to allow the engine to tolerate a ridiculously quick stab at the throttle, you are probably richer than the correct mixture.
And, of course, part of it's your fault. You have to learn not to brake stall the bike (clutch work, and develop a feel for when the engine is turning too slow), and learn to flip the clutch to restart on the fly more quickly. If you do it right, they fire right back up, and no one will even notice it was dead.
  • psmith85
Posted June 21, 2008 - 06:22 AM
I think that you need to start with your jetting. I am located at sea level and with very low humidty and just messed with the needle clip and the main jet. I went up 4 sizes on the main with the stock pipe before I felt I was going to rich. This is an easy thing to change.
  • 10 replies
  • On January 15, 2017
  • 0 replies
