scotts damper stock 05 450f w/vapor trail tech
3 replies to this topic
  • knucklehead
Posted June 19, 2008 - 11:34 AM
i know there are tons of post regarding the scotts damper on the wr 450f 2005 -i think ive read them all. what i want to know from you guys is if you have a pic or description of a scott damper with a vapor trail tech with the top mount protector and the scotts with a "reverse mount" on stock bars and triple clamp.
i really dont want to buy new bars b/c i have the ATK bar inserts in my stock bars and i would have to reorder them again and i just bought them a month ago. i would rather just bend the crossbar and remove the pad.
if you need more information please let me know.
thanks - Jerry
  • Just_a_trail_rider
Posted June 19, 2008 - 02:46 PM
I have scotts mounted on both my bike.
The wr450 has the scotts triple as well as the scotts bar clamp
The yz250 has the scotts bar clamp only. But I had to turn the damper around.
The important thing for the scotts is that you MUST get the scotts mount tack welded because the pinch bolts will not hold it properly. The first time you crash, that scotts collar will be loose and thus worthless to you.
here are a couple of pics
YZ250 (stock triple, scotts bar clamp, endurance computer)
WR450 (scotts triple, scotts bar clamp, endurance computer)
  • knucklehead
Posted June 23, 2008 - 10:04 AM
so did you get the "Weld-On Stabilizer kit complete" or the normal kit and have it welded?
thanks.
Posted June 23, 2008 - 06:36 PM
I got the normal kit that goes around the top of the steering tube and tried the pinch bolts that come with it.
A couple of good crashes (many of those in fact) and that thing kept coming loose. Nothing is worse than being on a ride and needing the stabilizer and the F***ing clamp comes loose making the stabilizer worthless.
Do youself a favor, get the weld on kit and have a bike shop charge you $25 bucks to weld it on. Besides, it will take you some time to take off your top clamp to put on the other one that just doesn't work.
