bewitched WR426F, jetting changes automagically
2 replies to this topic
  • Rowdy
Posted May 21, 2002 - 10:01 PM
2001 Euro model of a buddy of mine. ran fine,
fouled a couple of plugs until he got the idle
mixture right. when i bent my wr400f's shock
rod he loaned my his 426 for next day gravel pit
WFO hill climb extravaganza. all ponies very
alive and well, sweet throttle response.. :D
*a couple of weeks of neglect*
buddy and me drive to italy, break out the bikes
and his is a popping mess that won't pick up gas,
big, ugly hole when going from 1/4 throttle to
3/4 in a turn etc. :D
we ended up disabling the accelerator pump and
dropped the needle two notches => A#1 throttle response, no popping, first kick
starting, killer topend, super fine tricky
terrain throttle control blablabla. :D
*a couple of weeks of shed time*
he gets to a party and reports that he has to
have the choke on all the time, no idle and lotsa
hesitation w/o choke. :) Next day we set out for (last weekends) "riddle-ralley" so
instead of doing something ingenious we simple
take the carb apart, find all surfaces and jets
super shiny clean raise the needle back to center
clip and bike runs beautifully, again.
next day he stupidly fires her up for a minute
before setting up tent
Next morning, guess whose bike needs a fresh
plug. Furthermore turns out his 426 eats muuch
more gas than mine.
Later that day i decide to pass a rolling road
block going 90mph and buddy Nobs goes WFO too.
talk about killer acceleration..
but then...
all of a sudden right after the passing maneuver, his 426 is back in popping land,
banging the villages to kingdom come, loud enough
that Karin on the 1100GS can hear him detonating
while going +50 in the light drizzle. :D
The strange part is that vienna, Tuscany and the
Lower Austria area all are
- on similar elevation (within 1200 feet)
- the temps were at most 15°F apart
- my WR400F was around every time and ran
absolutely peerless w/o any adjusting
- his 426 is a low mileage bike, the carb to
cylinder head boot feels fine and looks
uncracked, carb slide is uncracked, too.
I'd have suggested he put the needle between the
.it and the stock pos, if it weren't for that
change in behavior after a short WFO section,
especially as we umm.. had an enormous WFO ball
on the twisty road catching up to our buddies BMW
and Transalp tankers after refueling w/o his bike
starting to pop again.
any clues how a bike can display such a Jekyll
and Hide personality?
  • GPS Dual Sport
Posted May 22, 2002 - 02:23 PM
This plug fouling - mystery jetting has been posted before. The cure was a new carb if I remember correctly.
Consider swapping carbs with the trusty WR400 that runs good. If the problem follows the carb to the other bike that will confirm it.
Is the bike still under warranty???
  • Rowdy
Posted May 22, 2002 - 09:48 PM
:) don't shock me like that! The carb as a spare is almost two grand without tax, over here!
Bike ain't under warranty anymore, so we'll try
that carb swapping test.
Anyhow, thanks for the suggestion
