WC rad cages with IMS 3.1 - 07 YZ450
5 replies to this topic
  • AZ Thumpdaddy
Posted June 17, 2008 - 07:46 PM
Does anybody know if the WC rad cages fit with the IMS 3.1 tank? Also, are you able to use thse stock white plastic cooling fins with this set up? I called Zip Ty today and they are out of stock and won't have them for awhile. Any down side with the WC cage?
Thanks for the help.
Posted June 17, 2008 - 09:04 PM
Try and advanced search on that. I believe it's been discussed.
http://www.thumperta...search.php?f=21
http://www.thumperta...board_searchtip
  • gtguy
Posted June 19, 2008 - 05:45 PM
I have the WC cages and an IMS on my 06, no problems. I will say the WC cages can be bent. I hit a pine tree square on the tip of my left radiator shroud. I made the shroud look like an accordion and bent the cage back some, but the radiator was undamaged. I went back to the truck, unbolted the shroud, straightened everything up and went riding. I think I got my money's worth on that one.
  • nap__kxf
Posted June 20, 2008 - 07:09 AM
well in all fairness at the end of the day its only metal, metal bends. but it did save your radiator and in my book it served its purpose.
  • AZ Thumpdaddy
Posted June 25, 2008 - 08:59 PM
I installed this combo today on my 07 and no problems. Need to use the longer bolts and spacers that come with the cage for the lower shroud mounts. Good stuff.
  • rickallen124
Posted June 26, 2008 - 07:37 PM
The Works Connection cages are great just make sure you use loctite on the bolts or they will vibrate out. Fit and finnish and that it doesn't affect air flow make them great braces.
