Changing a WR Tire
29 replies to this topic
  • Punisher660
Posted June 17, 2008 - 01:02 PM
:thumbsup: OK - How many of you use both rim locks on your WR?
I hate changing the tire on mine....my CRF is a piece of cake with only one rim lock. Are all of you still running both of them? Do you have any secrets for tire changes? The maxxis video that is floating around is great to follow if you have 1 rim lock, but does not address wheels like the WR's
Any ideas or input?
  • Dube2
Posted June 17, 2008 - 01:32 PM
I flipped my rear tire by myself one evening as I had to know how just in case on the trail i get into some dificult situation. (3) 8.5 " Motion Pro tire irons and a lot of muscle. Took a while but I did it.
Also, IMO the second lock is on the wr's/crfX as the enduro's tend to be used for crawling over largs rocks, bolders, fallen trees, river crossings and such. This is the most reason for the second wheel lock. If you plan on doing track with the WR? than I would say only one lock is needed.
Just my $.02
  • Just_a_trail_rider
Posted June 17, 2008 - 08:10 PM
Changing tires.... I still have scars all over my knuckles.
Then I got the 3rd tire iron. That's the secret.
I can change my tire with both rim locks in 20 minutes. With only two tire irons, I was never able to get the tire on or off the rim.
Good Luck.
go to www.motopowervideo.com. they have a nice DVD which walks you through the process.
  • MountainMax
Posted June 18, 2008 - 02:12 AM
that second lock can still be a pain, I made a proper stand, bought 3 tire irons and a bead buddy to help out, doing other tires are a snap but I still hate doing the WR with 2 bead locks......
  • byggd
Posted June 18, 2008 - 04:14 AM
Do a search and you will find many (including myself) only run one rim lock with no problems.
  • yz-dwg
Posted June 18, 2008 - 08:19 AM
for me it only takes an extra minute to install the second rimlock, I personally dont see the big deal with changing tires......
  • MountainMax
Posted June 18, 2008 - 01:28 PM
well yz dwg, you should change one and post a video for us to show us how easy it is for you, maybe we can learn a tip or 2 from you.....
  • bigdrtrdr
Posted June 18, 2008 - 04:10 PM
Im with you on this,
If you are struggling with changing tires your doing it wrong.
Personally I find 19" rears to be the hardest because of the short sidewalls.
One trick I have learned for removing a tire is to lever both beads off on both sides of the rim so the rim falls between the beads and is much easier to remove.
  • Punisher660
Posted June 18, 2008 - 06:02 PM
I have no problem changing a tire on any other machine.....CRF, YZ etc.....Its just the dang 2nd wheel lock that gives me a hard time.
I will try it out tonight and see if I can get 'er done.
I have changed the tire before, it's just much tougher than my other bikes. :thumbsup:
  • farkawi
One or two rimlocks makes no difference really. After the first hundred or so, you'll be changing them in your sleep. Three long tire irons with the big curve (like the often copied Michelin original ones), real tire mounting lube from Camel, heavy tubes and gloves. Practice, practice, practice
  • brad the best
Posted June 18, 2008 - 07:12 PM
just keep popping tubes , or wearing out your tire . you will get good at it . best thing is to get a mechanic to show you how to do it .
don't forget your gorilla snot !
i only run two locks because dirt went in the hole .
  • MojaveThumper
Posted June 18, 2008 - 07:13 PM
15 bucks and it is someone elses problem.
Tried it once, fought with it for 30 mins and said screw it. Needed something from the motorcycle store anyways.
  • MountainMax
Posted June 19, 2008 - 06:24 AM
it's ok if you have a motorbike shop close by, I do not, I do it, but still have problems with the locks, might leave one out next time.
  • Punisher660
Posted June 19, 2008 - 06:27 AM
Where do you get the "gorilla snot" - I've always used a solution of Dawn Dish Soap and water...... It doesn't seem to always work that great.
  • bigdrtrdr
Posted June 19, 2008 - 07:46 AM
WD40 is the best bead lube ever, Just dont get it on your rotor.
  • SJMC_DON
Posted June 19, 2008 - 08:10 AM
2 rimlocks are good idea -
1. The 18" tire equates to more rotating mass than a 19", while I have not actually seen it happen, this may be engineered to prevent tire slippage from a 18" tire.
2. Offroad riding vs. MX presents terrain that will be more likely to cause your tire to slip.
3. Riding out on a flat with 2 rimlocks is a lot more effective than doing it with just one.
I also second the WD-40 as a lube for the beads.
  • Demo_Slug
Posted June 19, 2008 - 09:16 AM
I use windex.:thumbsup:
  • timoyz1
Posted June 19, 2008 - 09:57 AM
WD40 isn't good because it will stay slick, and the bead might slip. A bucket of bead compound is only $10, and will last you a lifetime..
  • wRrooster
Posted June 19, 2008 - 10:20 AM
I've been running 1 rim-lock on my wr since day one, with no problems, just tape up the extra hole from the inside of the rim.
I find that a little dish soap mixed with water in a spray bottle works well, and won't potentially slip like WD-40 might?
The best thing I've found for changing tires is a bead buddy. You can get one from rocky mountain pretty cheap, or get the original design that rocky mtn copied from motion pro for more $$$.
With a bead buddy, 2 good levers and some soapy water, its almost too easy!
  • tribalbc
Posted June 19, 2008 - 10:36 AM
I've been running 1 rimlock on mine for 2 season's now including a half dozen races with no issues.
Our local dealer pull's them off all the wr's.
He says there's never been an issue :thumbsup:
