06 jumped a tooth??
2 replies to this topic
  • metalmulisha
Posted June 16, 2008 - 11:59 PM
hi guys just about to shim my valves and was just checking the valve timing, i read in the tech section on adj. the yzf250 valves that at the 12 o'clock timing marks there should be 12 pins on the chain between the 2. Is this the same for the 450 because mine has 13, could it possibly jumped a tooth any light on the subject would help
thanks alot
Posted June 17, 2008 - 05:29 AM
13 is correct on the 450. The count between cams is only dine as a cross check in any case. Use the timing marks against the cylinder head to time the cams.
  • metalmulisha
Posted June 17, 2008 - 01:41 PM
thanks gray, yes i am relying on the timing marks to the head i just read that and looked at mine to check and noticed the 13. :thumbsup:
  • Hot  50 replies
  • Hot  113 replies
  • On January 15, 2017
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  47 replies
