HELP,07 yz450f 5 gear tap out stuttering ?????
5 replies to this topic
  • SKEETERSS16
Posted June 13, 2008 - 07:21 AM
:thumbsup: I have a 2007 yz450f runs real good except in 5 gear tap out I have a very quick stutter or miss fire not sure??? sound like that anyway.Ive tried to go up and down on the jetting just to c if it would help, nope same thing.Ive check valves clearance they check ok,took the carb apart also check ok. Ive been running a DR.R pipe no problem last year.SR this is the best way a can explain this weired thing.I'm new to these 4 strokes so I'm lost right now don't know where to look.
  • WGP
Posted June 13, 2008 - 08:22 AM
Its most likely that your Main Jet is off a size or 2.
Posted June 13, 2008 - 08:23 AM
Does this occur only in 5th?
If so, does it occur through out the power range under haevy throttle, or only at very high revs?
  • SB105
Posted June 13, 2008 - 08:29 AM
it only happens when im in 5th gear, almost tapped, i can ride down a road 5th gear 3/4 throttle and it works fine, but as soon as i go full throttle, it starts acting up, from 1st gear to 5th gear 3/4 throttle the bike runs fine, but that last 1/4 throttle, not so fine haha, maybe something with the CDI??...maybe electrical??..not to sure not to familiar with this stuff
Posted June 13, 2008 - 08:48 AM
In your case, if the "miss" seems very pronounced, and mechanically almost violent, as if the chain were skipping teeth, it may be a worn set of gears (locking lugs on the sides) and a bent shift fork causing the gears to force out of engagement, then slam back in again.
If it really seems more like a miss, it could be a faulty plug, or it could be a main jet issue. If it is jetting, and the miss is regular in nature ("dot-dot-dot-dot"), it could be too rich. Check your air filter, and if it's OK, try a smaller main jet. If it's irregular, (like, "dot-da-dot-dadot-dot) (best I can do, sorry), and accompanied by an occasional loud pop out the exhaust, then you might lean, and need a bigger main.
  • trailsweep
Posted June 13, 2008 - 07:03 PM
I'm having the same problem and I've switch out everything that you could have switched on the bike, CDi,plug , plug boot , wire harness,stator and even a diff carb.. no luck...even put my carb on a diff bike and the other bike ran great.Also checked the timing and all is ok....called a tech from a race team and he said to do a leakdown test ? ok going to do this ....what do you guys think?any other ideas?
  • Hot  28 replies
  • On Yesterday, 06:20 PM
Motocross
  • Hot  491 replies
