Hour Meter Install
14 replies to this topic
  • Coastie3202
Posted June 12, 2008 - 10:27 AM
Got my hour meter installed today. After reading where everyone else mounted theirs I elected to try something different. I cut out a pocket on the crossbar pad foam and snugged the yellow Briggs & Stratton meter into the pocket, then cut a small square on the crossbar pad cover. I'm pretty sure it is not going to come out of there and it will be easy for me to see and reset.
Quick question - my hour meter, when the bike is not running, shows 0.0. Does the hour meter stayed powered all the time?
http://s297.photobuc...t=HourMeter.jpg
Posted June 12, 2008 - 11:49 AM
Different?
http://www.thumperta...575#post6508575
He's not the first, either. Sorry.
There is no source of power for the meter with the engine off. Many of them have an internal battery to maintain the display, and in some cases, the memory. If the meter resets to zero with each restart, it either has a missing battery, a bad battery, or is designed to use vehicle power for memory maintenance, in which case, it's probably not going to be suitable.
  • matt4x4
Posted June 13, 2008 - 04:23 AM
sounds like the battery in yours went dead - can you get a warranty replacement?
According to this document, once dead they're garbage, but in that case, for me it would be time to crack it open and see what can be done about fixing it - it may be flat Li-Ion that you can replace...
http://reviews.ebay....T:-1:LISTINGS:3
Posted June 13, 2008 - 06:16 AM
If it ever had one, and it probably did, that's undoubtedly what it is. Worst case would be to find it soldered in place.
  • Coastie3202
Posted June 14, 2008 - 07:32 AM
I think you all misunderstood. I have not run the bike with the hour meter installed yet, that is why it still reads 0.0. What I was asking was whether the meter numbers should stay visible all the time. I think the answer is yes since it obviously runs on a watch battery of some sort, not off a separate power source.
Posted June 14, 2008 - 01:39 PM
I understood, and my answer(s) are the same. :thumbsup:
  • Coastie3202
Posted June 15, 2008 - 06:53 PM
I ran the bike today with the new hour meter and it works great. Thanks for everyone's input.
  • roc_my_tims
Posted June 21, 2008 - 12:08 AM
what brand meter did you buy? cost?
  • Coastie3202
Posted June 22, 2008 - 04:32 AM
Briggs & Stratton, $20.00. Ordered from our local ATV/landscaping company. Any company that sells or services lawn mowers can order it for you. They may even have it on the shelf.
  • Ga426owner
Posted June 22, 2008 - 07:04 AM
ah.....I understood you.
The hrs the bike is on will stay displayed.....
  • Coastie3202
Posted June 23, 2008 - 04:08 AM
I'm glad someone finally understood my question. Thanks. After running the bike with the meter installed I realized that the display stays on, much like a digital watch. :thumbsup:
  • crooks420
Posted July 06, 2008 - 06:46 PM
Exactly where and how did you attach the red wire to the spark plug? Did you wrap it around the coil that sticks out of the top of the engine?
Jesse
  • Coastie3202
Posted July 07, 2008 - 04:07 AM
Yes. I lifted the rubber boot a little bit, took the first wrap under the edge of the boot, then took about 3 wraps around the body of the coil. I then wrapped it tight with electrical tape with a single zip tie to keep everything snug.
  • PitDad911
Posted March 07, 2009 - 01:01 PM
I have a hourmeter on my sons bike but don't get a good reading it says to wrap it around the sparkplug wire but on these bikes they don't have a plug wire i see two wires that go into the coil do i wrap around one of them? he has an 08 rmz250?
  • spc mike
Posted March 08, 2009 - 02:00 PM
Dude....you question was just answered in the previous post.:p
  • Hot  47 replies
  • Hot  113 replies
  • Hot  50 replies
Motocross
  • Hot  491 replies
