Stupid front wheel question
5 replies to this topic
  • RenoMike
Posted June 11, 2008 - 05:31 PM
I searched but couldn't find anyone wiling to ask as stupid a question as this.
03 450.
It's got a big allen hole on the right side, presumably "The Axel."
And a 22mm nut on the left side.
Pinch bolts are loose on both sides.
Now, this 22mm nut on the left side is like 3mm WIDE. So it doesn't really like a lot of torqueing on it. I have the bike on a stand and with a ratchet on the nut, I can STAND on the ratchet and it doesn't budge an inch. At first I turned the Allen head on the right side but it just kept spinning the Nut on the LEFT side. So I tried the nut on the Left side.
Question. Did I turn the allen head and really REALLY tighten the nut? Should I get a 22mm spanner and hold the nut in place while turning the allen head? Or should I just put the ratchet on it and start banging away on it till it breaks loose?
Or am I just missing something completely.
Sorry for the dumb question, but I'd rather look dumb and do it right than break something and look even more dumb.
  • Wiz636
Posted June 11, 2008 - 06:07 PM
Tighten the pinch bolts.
Remove the nut with a 22mm socket. Loosen the pinch bolts, remove axle.
You are trying to turn the nut counter-clockwise...right?
When you put the axle back in that nut gets torqued to 75 ft/lbs.
Posted June 11, 2008 - 08:49 PM
Be sure the axle pinch bolts (two on each fork leg) are tight while attempting to loosen the axle, then turn the nut counterclockwise as you normally would.
To tighten:
http://www.thumperta...886#post5007886
  • RenoMike
Posted June 11, 2008 - 09:41 PM
Ok I'll try it that way. Problem is that the nut isn't turning at ALL.
Might need a breaker bar. As long as I'm not missing something I'll tighten the pinch bolts and put some muscle into it.
And yes I'm turning it counter clock wise :thumbsup:
Thanks for the replies.
  • intensem1rider
Posted June 12, 2008 - 03:26 AM
You could always break out the air tools :thumbsup: My friend is a hammer head when it comes to working on his bike so when I get my hands on it, I need to use the impact gun to get his bike apart, but it works!
  • sparkyz
Posted June 12, 2008 - 11:35 AM
Here's a tip to turn or hold the hex head... You can use a spark plug socket, remove the rubber and you'll see that the hex side of the large spark plug sockets fits perfectly in there. Then you can use a 3" extension going the wrong way into the plug socket and a ratchet... Hope that makes sense.
  • Hot  50 replies
  • Hot  113 replies
  • Hot  28 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • On January 15, 2017
