TrailTech vapor on 07 WR450
27 replies to this topic
  • tweav
Posted June 15, 2008 - 11:27 AM
#21
http://www.promotobi...products_id/291
and it carries all the things that matter too. :thumbsup: :busted: :busted:
  • steve350f
Posted June 16, 2008 - 06:29 AM
#22
$185 for the rack!! Ouch, but I guess it's worth it if it carries a case of coolies. :thumbsup: Anyway, another question, Which hose should I attach the temp sensor too? The one from the top of the rad to the engine or from the bottom of the rad to the pump? What did you set your two warning light temps at?
  • tweav
Posted June 17, 2008 - 10:08 AM
#23
I hooked mine to the upper line as close to the head as I could It's the hot one . temp light yellow 210 f and red 240 f . the shift light I set at 10000 rpm yellow red 11000rpm . yes 186 is salty for a rack but I use it a lot
  • Dominion
Posted June 17, 2008 - 10:37 AM
#24
You have inspired me! I am going to attempt to plate my WR here in the next couple of months and I gotta super moto it! Where'd you score those rims? Thats a great looking bike brother!
~Brian
  • tweav
Posted June 17, 2008 - 12:03 PM
#25
I got the rims from a guy on www.supermotojunkie.com . they were used . a plated wr is a blast to ride but it is a high maintence bike .
  • sirjolly18
Posted March 07, 2013 - 11:51 PM
#26
on my 04 wr450 f i am having trouble running the power wires and connecting to the ignition. The ignition has black and red. i only have the black wire from the speedo plugged into the black from the ignition wires, but when i attach the red wire from speedo it will light up even when i have the key set to off. Why is this? So atm i have left only the black wire in which seems to work when key is turned on with no dramas. does the red wire from the speedo need to be attached to something? does the trail tech automatically turn off after 15min of being inactive which means having both plugged in will be fine?
i have the rpm wires attached to plug and black grounded to the frame.
  • miweber929
Posted March 08, 2013 - 05:16 AM
#27
It should turn off after 15 minutes of inactivity but will drain your battery for that 15 min.
Get a manual, find the wiring diagram and use a switched power wire, don't just match wire colors. Using a switched power wire, by switched I mean something that isn't live until after the ignition button is pressed on or something that doesn't get power until after the bike starts, will make it work correctly.
Have a Vapor on mine and works like a charm turning on and off with the ignition. If it or the manual was in front of me I could tell you exactly what wire I used but this way you'll get the satisfaction of finding it yourself!!! :)
Edited by miweber929, March 08, 2013 - 05:19 AM.
  • Luv2brap-downunder
Posted May 24, 2015 - 01:33 AM
#28
Hey guys I got my vapor in the mail today and the instructions confused the &%$#@! outa me, got a couple questions for ya. Where abouts did you put the temp sender, so it doesn't run on the tank.
How many times did you wrap the rpm sensor around the spark plug lead ?
