countershaft seal removal
6 replies to this topic
  • CAVSCOUT96
Posted June 10, 2008 - 08:01 PM
OK... this thing is kicking my ass. How do I get the seal out without f'ing up the shaft or the case. I tried the screw method, but no luck. I think I seated it too far when I installed it.
Thanks in advance!
Posted June 10, 2008 - 08:51 PM
Start by giving the end of the output shaft (with the sprocket removed) a sharp tap or two straight inward with a plastic mallet or with a block of wood and a hammer. That will break the bond between the sealing collar and the shaft. Then, using a pair of channel lock pliers and a strip of rubber or tape to protect the collar, twist and rock the collar out of place and off the shaft.
Once the collar is out, the seal can be fairly easily hooked out with a screwdriver or other implement.
  • CAVSCOUT96
Posted June 11, 2008 - 02:53 AM
Thanks!!
I'll try it later today. I searched all over the forum, but couldn;t find an earlier post i'd seen with pics. Never thought about taking the colar off first. I couldn;t find anywhere in either the service manual or teh Clymer's manual where they addressed the removal of that seal. Talk about aggrevating!!!
Thanks again!
  • matt4x4
Posted June 11, 2008 - 04:19 AM
Also - remember to replace the oring located on the shaft behind the collar.
another way to pull the seal after collar removal - 2 screws opposite each other, grab with 2 pliers and perform on good yank simultaneously it'll pop right out.
use a rubber mallet to gently tap the new seal in.
while verything is out, check for side to side play on the countershaft, if ANY exists, it might be time to do bearings before you get into a grenade situation.
  • CAVSCOUT96
Posted June 11, 2008 - 07:28 AM
Thanks Matt,
I've replaced the seal before, but never the o-ring. I'll definitely check and replce if necessary. Shaft itself is nice and solid. Thanks for the tip, I din;t realize the collar could be removed first.
  • CAVSCOUT96
Posted June 19, 2008 - 05:45 PM
OK guys,
replaced the o-ring AND the seal.... STILL leaking.
cleaned the surfaces
lubed the oring and seal
seated the seal flush with cases
tighten the sprocket to specs
Still leaking!!!!
What now?
thanks in advance
Posted June 19, 2008 - 10:54 PM
If the collar has any significant groove worn into it, replace it.
