450 missfiring help!
5 replies to this topic
  • trailsweep
Posted June 09, 2008 - 03:30 PM
Ok here goes it...07 yz450 stock with fmf 4.1 with jd kit installed.
The bike has a bad miss fire above half throttle and i think its an electrical miss. I've had it on a dyno and have the readings to prove that its not jetting(air fuel metter readings) Anyone have any problems with the cdi boxes on these bikes? And also I did unplug the TPS with no luck, also checked the nuetral switch out with an ohm meter and it is within specs....so this is killing me...thanks to all who replie:thumbsup:
  • urgreathero
Posted June 09, 2008 - 03:36 PM
i had a couple miss fires on my 07 but all i did was put a adj fuel screw and a 48 pilot jet in and it clean it right up
  • trailsweep
Posted June 09, 2008 - 04:30 PM
yep thats what it sounds like alot of them are doing but not mine of course..
  • mx614
Posted June 11, 2008 - 07:11 PM
Yep my 07 yz450 did this as well with the DR.D full system, after calling them and rejetting it didnt help. removed and reinstalled stock pipe and it cleaned right up,sold DR.D on Ebay and riding stock now. A Yamaha rep said that with the new 07 and up cams and ignition specs it doesnt help to add an aftermarket pipe unless you change the cams. they said its designed to run slightly corked up. Hope this helps.
  • Ballinator
Posted October 10, 2013 - 07:11 PM
Check the ignition coil connector. I had the same problem,
Posted October 11, 2013 - 07:56 AM
[...] the new 07 and up cams and ignition specs it doesnt help to add an aftermarket pipe unless you change the cams. they said its designed to run slightly corked up.
Not true.
Motocross
  • Hot  491 replies
  • Hot  50 replies
  • Hot  113 replies
