E-batt
11 replies to this topic
  • jj546
Posted June 09, 2008 - 01:47 PM
Who's tried the rechargeable dry cell ebatt, and are you happy with your purchase? I have an 03 WR450, the battery is dead and an offbrand is $40 and a Yuasa is $140. I have no problem with kicking, but with all the crap to remove, it just as well work.
John
  • tribalbc
Posted June 09, 2008 - 03:42 PM
I have one on my 07 and couldn't be happier. But mines a different setup than yours would be. An 07 draws on the battery for the tailight and odo. Therefore I can get away with not disconnecting the charging system. So I have a 2lb battery that holds a better charge than stock.
You would probably have to disconnect the charging system so if you don't mind charging the batt once in a while it's all good.
  • chrispy1202
Posted June 12, 2008 - 12:36 AM
5 Years of magic button starts makes that $140 seem pretty easy to spend.
  • PhAcEpLaNt
Posted June 12, 2008 - 05:38 AM
I wonder how this battery would do using full light systems (like Trail Tech) on the bike with a stock stator...seems like it would eliminate the need for a rewound stator. :thumbsup:
Any thoughts?
  • tribalbc
Posted June 12, 2008 - 09:35 AM
I think it's possible. You definately always have alot of charge and they say rewound stators are a problem with too much power.
I'm putting a higher watt (45W) in my bike but someone should really try something that sucks some juice.
  • RickSanson
Posted June 12, 2008 - 09:47 AM
I assume then that you never need to externally charge the E-Batt. Is this correct?
  • tribalbc
Posted June 12, 2008 - 12:42 PM
No in fact I try to use my e-start as much as possible to avoid overcharging the battery. That's why a strong light system could be a good balance for this system....
  • Demo_Slug
Posted June 12, 2008 - 05:40 PM
No in fact I try to use my e-start as much as possible ..
turbo boost button. :thumbsup:
actually, I'd try 6 of thease. two banks of 3. Each battery has a protection circuit board attached onto the head of the battery. mainly used for high power flashlights.
http://www.dealextre...ils.dx/sku.5776
  • wr_matt
Posted June 12, 2008 - 05:53 PM
So how does the bike feel without the extra weight in the saddle..? :thumbsup:
  • tribalbc
Posted June 12, 2008 - 07:37 PM
I'd say you definatly feel a difference in the slow side to side. I have the added bonus of a 08 yz exhaust so I've lost 6-7lbs total in the upper seat area. That I notice :thumbsup:
  • PhAcEpLaNt
Posted June 13, 2008 - 06:00 AM
Thanks for the input on that...it definitely seems possible that HID headlamps and helmet lights should work with this battery without a rewound stator. I currently use a Trail Tech SCMR16 helmet light (wired to the bike) and a 35 watt headlight and have had no issues with that. The total wattage, I'm guessing is around 70 watts. If I use the Trail Tech extreme headlights that would probably make the total around 125 watts. I think that's worth a try...a great option to save money and shed a little weight:thumbsup:
  • tribalbc
Posted June 13, 2008 - 06:57 AM
Let us know how it goes :thumbsup:
