Anyone have there coil off there 426 or have a really good memory from when they did!
6 replies to this topic
  • skibum_1260
Posted June 08, 2008 - 04:17 PM
C:\Documents and Settings\Dustin\Desktop\Dustins stuff\Kodak Pictures\ebay\ww 012.jpg
my 426 started making alot of noise, and metal savings appeared so i tore it down and found a 8mm cap head bolt(.5 inch long maybe) sitting between the crank main bearing and the cam chain on the bottom end, im assuming it came out of one of the holes i circled on the picks, can anyone verify this? and the other hole never had one, does it need it? i cant find anything detailed enough in the diagrams. thanks alot!
  • skibum_1260
Posted June 08, 2008 - 04:18 PM
well i dont have anywhere to host the pick so not sure how else i can load it, but theres 2 holes on the left hand case behind the stator plate, both threaded all the way threw, both next to the main bearing.
Posted June 08, 2008 - 05:10 PM
Google Photobucket. It's free.
  • skibum_1260
Posted June 08, 2008 - 05:30 PM
http://i235.photobuc..._1260/ww012.jpg
http://s235.photobuc...rrent=ww012.jpg
  • SXP
Posted June 08, 2008 - 09:38 PM
The threaded holes are used to secure a puller to draw the left side case off the crank. They are normally empty. Look elsewhere for the source of your bolt.
  • matt4x4
Posted June 09, 2008 - 05:04 AM
By the sounds of it, your bolt is number 10 on this pic....
Posted June 09, 2008 - 08:46 AM
Check the bearing retainer plates inside the crankcases. The circled holes are for tool installation only, as was said, and are normally empty.
  • Hot  36 replies
  • 9 replies
  • Hot  47 replies
