2007 WR 450 Plastic/Seat conversion
10 replies to this topic
  • sbc61
Posted June 06, 2008 - 12:17 AM
I would like to put all white plastic on my 07 WR 450, to make it look like the white YZ 450F. I figure I will need the following: front fender, radiator shrouds, rear fender and front number plate or headlight assembly.
I would also like to use a complete seat assembly, like the SDG complete tall seat.
Will the YZ plastic and seat for a 07 or newer YZ 450 work on my 2007 WR 450?
Has anyone done this?
Is there a complete seat assembly available for the 07 WR 450?
I really like the look of the white 07-08 YZ and think it would look even better on my WR.
Any info will be appreciated.
  • tweav
Posted June 06, 2008 - 12:58 AM
on a stock 07 wr450 the only pieces of plastic from a yz that will bolt right on is the front fender and the left lower fork guard . you can buy almost if not all the parts for a wr in white . I'm not sure about the headlight , have not seen a white stock shell .The yz rad shouds will fit if you use ether a yz tank or an ims tank.
  • sbc61
Posted June 07, 2008 - 04:56 AM
Thank you tweav, you just saved me some money in return shipping costs.
  • yz450fguy
Posted June 07, 2008 - 07:48 PM
I got YZ shrouds to fit, but one of the mounts under seat wasn't perfect. Looked pretty good though.
  • driftevo361
Posted June 07, 2008 - 08:43 PM
gettin cocky :thumbsup: :busted:
  • jd99
Posted December 28, 2008 - 08:15 AM
i did that conversion to my wr 450 2007 with the white plastics by ufo with the
copy of the original rear fender so the CDI fits ok
  • mightymart
Posted December 28, 2008 - 09:24 AM
Acerbis do a all rubber black seat (X seat) bolts straight on.
  • Paulsy
Posted December 28, 2008 - 12:16 PM
You can buy the complete GYTR kit here in NZ (so I assume you can get it in the US). It comes with the rad shrouds, guards, headlight surround, bar pad, decals and seat cover. See this (now finished) local auction:
http://www.trademe.c...px?id=194049188
Ask your dealer.
  • Racegun
Posted December 28, 2008 - 10:57 PM
Hey mighty mart have you seen the Acerbis seat bolted on a alloy framed wr, has any one seen one , used one?They only listed a yz model??
  • mightymart
Posted December 29, 2008 - 03:05 AM
Only what I have read !
  • Racegun
Posted December 30, 2008 - 01:27 AM
Thanks mightymart , Ill ring the importers and check what i can get off them and how much.
