Dodgy WR400 box...
1 reply to this topic
  • paulospug
Posted June 05, 2008 - 11:30 AM
:thumbsup:
Hi.
Today I bought a WR400 Yammy, and checked oil, bearings, everything..... apart from 5th gear!!! :busted:
When trying to go into 5th as I have now discovered, it does nothing but makes a weird sound.
Someone said this is common on these bikes...
Is this true? If so, how bigger job is it and what costing does it involve?
Ta.
Paul
  • matt4x4
Posted June 06, 2008 - 04:12 AM
Depends on what you can do yourself, up here in Canada, don't expect to get away with less than 2500 having a shop do it, you can do it for about 100-200 in parts doing it yourself, however, when tearing into a bike that old, that far, it's probably a good idea to replace what you feel is necessary to make your bike a good investment for some time to come.
I had a single bearing go, decided to replace all the case bearings, 2 and 3 gear, oil pump, output shaft, new rings, timing chain, shims, honing, gaskets, asst. hardware - total cost - about 600US total
here's what's involved - and it's nowhere near as bad as it looks.
