Intake cam lobe????
1 reply to this topic
  • brent426
Posted June 04, 2008 - 06:36 PM
Just rebuilding my 426 and noticed the center cam lobe engages first before the right and left lobes. Just checking to see if this is normal. I know the valves are at different angles. Any help would be appriciated. Thanks
Posted June 04, 2008 - 06:53 PM
If you put a dial indicator on the lifters as the cam is rotated, I think you'll see them all open at the same time due to the difference in angle between the center and outer valves. The center lobe is offset from the others for this reason.
  • Hot  36 replies
  • On January 15, 2017
Motocross
  • Hot  491 replies
  • 0 replies
  • 10 replies
