coolant leak?
5 replies to this topic
  • kbike
Posted June 04, 2008 - 02:08 PM
Today I looked at a low mileage 04 WR, and it had a white dry substance, like maybe coolant, coming from the small hole on the right side of the head. It made a line down to the base of the cylinder. Any ideas what this is and what might have caused it? The FAQ only talks about the hole down by the waterpump.
  • swede426
Posted June 04, 2008 - 02:17 PM
Is it oily consistence
  • kbike
Posted June 04, 2008 - 02:22 PM
It's a white dry powder residue from some kind of leak.
  • swede426
Posted June 04, 2008 - 02:41 PM
Ok, then its not from any of the venting pipes on valve cover.
Maybe the head is'nt properly tightened...?
  • maxtherat
Posted June 04, 2008 - 07:25 PM
It's a drain in the event water gets into the cavity that the spark plug goes into. Pull the cap off the plug and blow air into the hole and you will see it.
  • kbike
Posted June 05, 2008 - 06:47 AM
Thanks Max, that's just what I wanted to know.
kbike
