wr 426 no spark
2 replies to this topic
  • Thaulass
Posted June 03, 2008 - 07:46 PM
Have an 01 wr 426 finally put new piston and timing chain in it . Ran fine for break in, next week going for nice ride and bike died and wouldn't start. I took it back to the shop who did top end and we could find nothing wrong except for the intermitent spark. Bike has a Baja Designs st legal kit and never has failed to start first kick . Shop owner was no help saying its electrical, could replacing timing chain have knocked loose wire in stator anyone have this happen to them? I just need a starting point.
  • matt4x4
Posted June 04, 2008 - 04:42 AM
Check your Coil - the bolts that hold it on the frame are grounds - clean them and the frame they mount to.
Check your electrical connectors (under gas tank) where the stator plug connects to the harness, could be a bad connection there...pretty much just work your way through your electrical once verifying everything, it shouldn't take more than an hour and could be as simple as that.
  • Thaulass
Posted June 04, 2008 - 07:04 PM
thanks the sop didn't disconnect any wires I've check all conn even pulled the stator off and checked the conn there .still confused
