Help with wr400 rear tire size
1 reply to this topic
  • bultaco
Posted June 01, 2008 - 12:49 PM
Just purchased a 99 in good shape. Rear tire is a 110/80-18...shop manual says 110/100-18 standard.....What tire to use for overall riding? Interesting to see that the european version runs:
US:110/100-18 rear 80/100-21 front
EU: 120/90-18 90/90-21 front
How come the difference? thanks
  • husqvarnarider
Posted June 01, 2008 - 02:47 PM
The 110/100/18 will be taller, by 30mm. You'll get a slightly smoother ride, more resistance to pinch-flats, and a little more top-speed :thumbsup: The 110/80/18 is 110mm tread width, and 88mm sidewall height. The 110/100/18 is 110mm wide, and 110 sidewall height. I run 110/100 or bigger on mine. The michelin S-12s are confusing.....I run a 130 series in them.
