How Can I run 87 Octane Fuel?
46 replies to this topic
  • MountainMax
Posted May 31, 2008 - 08:27 PM
I know we are suppose to run 91 octane fuel however i have to drive 480km round trip to the nearest (and only one in my province of Labrador) gas station that sells Supreme. How can I mod the bike to run regular fuel instead? thicker head gasket? lower compression Piston? retard the timing? colder plug? what can I do??????
  • swede426
Posted May 31, 2008 - 08:29 PM
Maybe try some additives to the gas...?
  • MountainMax
Posted May 31, 2008 - 08:33 PM
You need alot of that additive to make it work, and it's very expensive, would be cheaper to run to the gas station a few times a year and stock up.....
Posted May 31, 2008 - 08:35 PM
You can boost the octane of your 87 octane regular by mixing in toluene at about 15%. It's available at paint and hardware outlets for much less than commercial additives. Add about 20 ounces for each gallon and fill the can.
  • MaxPower
Posted June 01, 2008 - 04:05 AM
[COLOR="Green"]I have run regular in my WR many times with zero problems. Thats beating the crap out of it and road rides in 5th gear. I run a YZ cam and the gray wire cut with a pipe. I love these bikes[/COLOR]
  • PBDBLUE
Posted June 01, 2008 - 05:38 AM
Well with a 12.5:1 compression ratio and no detonation sensor (ala fuel injection) you're a very lucky guy. It's pretty likely there's some detonation going on but as much noise as these bikes make you may not hear it. That's not to say you can't run regular in an emergency but for normal riding I wouldn't run anything less than premium. If you want to set it up for regular you need to get the compression ratio down to something reasonable (9.0 - 9.5:1 at most). Don't know if you can get there with just a head gasket. Probably gonna take some machine work like a custom piston. Oh and be prepared for a significant drop in performance.
  • ghrocketman
Posted June 05, 2008 - 09:47 AM
Buy some Octane Supreme 130 from "battery stuff.com".
It is pure tetraethyl lead fuel additive in a bottle.
.5oz (about 15mL) per gallon (3.79L) of fuel will raise the octane 2 numbers from 87 to 89.
Using 1oz. (30mL) per gallon will raise the octane 3.5 numbers to 90.5, which should be okay. this stuff costs about $15/qt (973mL) including shipping in the US for two quarts
Is there a small airport near you ?
If so, purchase & mix AV100LL AvGas 50/50 with your 87 octane fuel and it will be 100 octane using the normal (R+M)/2 "pump octane AKI" rating system.
Mixing it 25/75 with your 87 octane fuel will give you about 93 octane fuel.
AV100LL is 100 MOTOR octane and about 112 pump octane.
Using AVgas is usually much cheaper than blending in Octane Supreme 130.
Be aware AV100LL AvGas is highly leaded and will require you checking your spark plug more often.
  • MountainMax
Posted June 05, 2008 - 12:09 PM
Thanks, there is no private airport, but last year i drove the 300 km and bought a drum of 100LL for my snowmobile, but if i have to drive to get that, just as easy to fill the drum with supreme, hehe
  • sfraser
Posted June 05, 2008 - 04:24 PM
I buy octane boost from Notre Dame in Goose Bay which only woks out to about an extra 15cents a liter...not much more than supreme. I mix it a little more than it suggests. It is about 7.50 a bottle and does 2 - 5 gal cans.
  • sfraser
Posted June 05, 2008 - 04:28 PM
also, I know your quite aways from there, but people going to and from often and if there was someone you knew making the trip probably wouldn't mind picking something this small up and dropping it off to you
  • MountainMax
Posted June 05, 2008 - 05:11 PM
that brings up another myth, you know how octane boost says it raises octane level 5 points say, that means, it brings it up from 87 to 87.5 not up to 92 like you would thinkg, it's a rip off......
  • Ak Yammy
Posted June 05, 2008 - 07:02 PM
Wow, this is all news to me. I've had my '03 for almost two years now and have run 87 the whole time never knew I was supposed to run higher. No damage that I know of or pinging. Guess I'll do 91 now, I love this site.
  • MountainMax
Posted June 06, 2008 - 02:27 AM
I know others that run 87 also without problem, maybe it has to do with the way it's driven also, im sure in a race type aplication it would detonate so bad it would damage the engine, but other then that it may be ok, barelly...... However I will continue to run 91, it's my buddy who wants to run 87,
  • wild west al
Posted June 06, 2008 - 06:51 AM
in australia we get fuel in most stations which is rumoured to be as high as 97 ron but its so crapy that it kills valve seats and caused problems in early titanium valve engines so I run a product called flash lube which is about $25 for 1 litre and it makes 1000litres of fuel .Its an upper cylinder lubricant that also slows the burn of the fuel and has the same effect as a higher octane rating .I have use 1 litre in my wr 400 and rebuilt the engine once .It was smick inside when i stripped it .I wiped the valve tops clean with a rag .no signs of detonation on the piston or the big end .Its also used in early cars running lpg/fuel .OH WELL im a believer .lol
Posted June 06, 2008 - 07:12 AM
Octane number has nothing to do with the burning rate. Octane is resistance to detonation.
Detonation is most likely to occur at low RPM under a load, although it can happen any time under the right circumstance. Riding at high altitude reduces the octane requirement because the lower air density decreases the dynamic compression.
How octane is rated also bears on the question. There are two methods; Motor and Research. The Research method generally produces a higher number at any given level of detonation resistance. The requirement in the manual is for 95 Research octane. The same fuel rated by the Motor method would be around 86-88, and by the method used to label US gas pumps, an average of both methods, it would be 90-92.
  • wartsnuff
Posted June 06, 2008 - 09:11 AM
Detonoation will happen anywhere
load and top end load as well.
octane rating is the flash point.. burning speed.
  • sfraser
Posted June 06, 2008 - 10:14 AM
Didn't know that, but before I used it I had detonation, but after adding it it stopped. I was also thinking of buying 110 octane from a local dealer. What ratio would you recommend mixiing it with regular gas. 70-30?
Posted June 06, 2008 - 12:25 PM
No, it isn't. Nor is it ignitability, nor energy content.
Octane is the resistance of a fuel to ignition during the compression or combustion cycle from any source other than a spark or open flame. While the factors that influence detonation resistance can affect the burn rate, flash point, etc., they are NOT directly associated with a fuel's octane rating, and fuels with any given octane rating may be found with any of those other values all over the map.
Read:
http://www.thumperta...255#post2920255
  • ghrocketman
Posted June 08, 2008 - 05:58 AM
I won't run 87 octane GARBAGE fuel in ANYTHING including my lawn mower.
I'd run my Torco leaded 110/Klotz R50 2-stroke fuel mix in my weed-eaters and riding tractor before 87 and have done so.
87 octane pump fuel is a "Forrest Gump box-o-chocolates" disaster for quality and consistency.
Posted June 08, 2008 - 07:12 AM
Two-strokes are entirely different, and information regarding their fuel requirements has no application in a discussion of four stroke engines. The main difference is that the 3-5% engine oil content of pre-mix fuel lowers the effective detonation resistance of the mix, so that you have to start out with a higher octane rated fuel in order to get away with it. A YZ450 with a CR or 13:75 can run 91-93 octane fuel (R+M/2 method), whereas a two-stroke running at 12:1 is often lucky to get by with 100.
