2009 YZ450F Info June 6th
89 replies to this topic
  • Wiz636
Posted June 09, 2008 - 09:27 AM
#81
The idea of offsetting the axle hole 1.5mm upwards would work but then it is changing the geometry of the bike. I would rather that the blocks incorporate a collar that fit inside the axle slots in the swingarm so that the axle would remain centered vertically. Do you think that 6000 series aluminum would be up to the task or would Ti be necessary?
Posted June 09, 2008 - 09:48 AM
#82
If the material were thicker, the aluminum would likely be adequate, but the fact that the wall thickness of the collared portion would be only 1.5mm (.059") concerns me. So, my thought would be offset the axle vertically (no effect on geometry), or use Ti or steel for the blocks.
  • Yamahafan
Posted June 09, 2008 - 01:57 PM
#83
Will you need a bushing to keep the 2009 brake caliper frame with a 25mm hole from sliding up and down 3mm on the older 22mm axle or will the pressure from the wheel and swingarm on both sides keep it from moving?
  • Wiz636
Posted June 09, 2008 - 02:17 PM
#84
It would make sense that it would need to have a bushing. Also, the odds that the wheel spacers designed for the 22mm axle will fit on the new hub is probably slim to none.
  • Dicko187
Posted June 09, 2008 - 11:39 PM
#85
Regardless of the swing arm spread, how do you propose to keep the axle from sliding around in the larger slots?
use the '07 axel blocks aswell?
it should fit :thumbsup:
i've questioned my dealer about it, he has no idea as of yet, but he said he will be ringing Yamaha Australia today to find out some info about the bike etc. and he's going to ask them if stuff like that is possible.
but like someone has already said, all will be reveiled once the first lot hit dealer floors.
man i hope the wheels fit over. not keen on black rims in mud again.
i had them on my old 250F...one sandy 'mud' race and they were stuffed.
then again, nothing black texta's can't fix, right? :busted:
Posted June 10, 2008 - 06:31 AM
#86
We talked about that:
So, then, You intend to support the entire vertical load at the axle with blocks that will in turn be supported only by the ledge over the top of the blocks (not intended to bear weight)? Or maybe you were planning to offset the axle hole 1.5mm upward? :busted:
Bad idea.
  • Wiz636
Posted June 12, 2008 - 02:09 PM
#87
So...has anybody heard when the '09's will be hitting the dealers?
  • Family Man
Posted June 20, 2008 - 02:38 PM
#88
In july the bikes willbe available according to my local yamaha dealer. Small changes can and do add up, these bike are improving from year to year. They are good bikes.
  • kyle450rider
Posted June 21, 2008 - 12:51 PM
#89
Were they available this time last year? I can't remember. If this is true I need to hurry up and sell my 2007.
  • Family Man
Posted June 21, 2008 - 02:41 PM
#90
Yeah it was june or july last year that the dealers began receiving bikes.
Motocross
  • Hot  491 replies
  • Hot  28 replies
  • On January 15, 2017
  • Hot  36 replies
