2005 WR450 Dead Spot
2 replies to this topic
  • Marc WRP
Posted May 29, 2008 - 12:36 PM
I have a really bad dead spot just off idle. I have swapped out all electronic components off of my other bike and it did not solve the problem. But when i unplug the TPS the problem goes completely away. So i bought a new TPS and it did not cure the problem. When TPS is off of the carb but plugged in I still have the stutter so i am assuming it is electrical. Has anyone ever seen this before? Will i damage anything running with the TPS disconnected?
Any help would be greatly appreciated.
Thanks
:thumbsup:
  • matt4x4
Posted May 30, 2008 - 03:46 AM
If you actually adjusted the TPS properly and the problem still exists I would have to say it's your AP timing.
I cleaned my carb during the winter, added a performance pipe and when spring came I had the same issue.
I adjusted my AP squirt timing which took about 1/8th of a turn in and everything was great again.
  • Marc WRP
Posted May 30, 2008 - 04:28 PM
what is the proper way to adjust the TPS
