any guides to checking/repairing starter motor
4 replies to this topic
  • rozero1234
Posted May 28, 2008 - 10:17 PM
my 03' WR is finally running strong, and i switched the starter clutch. the starter button never really worked, and after some pretty gnarly uphill rides, i really wish i had a magic button.
i'm gonna check all connections tomorrow, but i was wondering if there were any guides out there on how to repair a startor motor, preferably with pictures.
  • William1
Posted May 29, 2008 - 03:24 AM
To service an electric motor, common jobs are:
Clean internals
Replace brushes
Cut commutor
Test on a Growler
The last two have to be done at an eletric motor shop (unless you have a metal lathe, then you can cut the commutor)
  • rozero1234
Posted May 29, 2008 - 03:05 PM
sounds pretty straight forward. how do i know when to replace brushes? i've never seen the inside of a starter before.
  • PBDBLUE
Posted May 30, 2008 - 06:51 AM
One more tip. Mark the orientation of the housing pieces before you take the motor apart. The position of the magnets is important when you reassemble it.
  • rozero1234
Posted June 02, 2008 - 09:21 PM
good tip thanks.
