08 Wr450 Bent Subframe
6 replies to this topic
  • WIRE-DOC
Posted May 27, 2008 - 09:01 PM
I Twisted My Subframe In A Crash. How Do I Go Abuot Straightening It Back? Just Bend It Back With A 4x4? I Did Not Take Measurements Because It Is So Obvious. All Rear Plastics Are Off. Now What?
  • Looks450
Posted May 27, 2008 - 11:16 PM
Secure the bike really weel, then get the biggest hammer you have and beat it back into shape.
  • doctorchopper
Posted May 28, 2008 - 12:57 AM
secure bike then use a comealong or chain and tackle, or better yet look for a new one, might be hard to find a used one being so new
  • w00dsRider
Posted May 28, 2008 - 03:26 AM
I bent the sub-frame on my 06 and used some square bar stock (two pieces about 4 feet in length each) and used some huge hose clamps to attach them to the end of the sub-frame (both sides). Braced the lower rear part of the frame against a wall and had somebody hold the front of the bike so it wouldn't move. This gave me the leverage to twist the sub-frame back in shape. "Supplies" cost around $10.
  • WIRE-DOC
Posted May 28, 2008 - 09:15 PM
do it on the bike, or take the subframe off?
  • w00dsRider
Posted May 29, 2008 - 02:44 AM
I did mine on the bike much easier to see what direction you need to go and when you've got it right. Also check the sub-frame mounting bolts, mine were bent as well. Good luck!
  • tblrk2008
Posted May 29, 2008 - 10:52 AM
Be careful you dont weaken the metal.....not all types have a memory and come back into shape with the same strength.
