Additional Hand Guard Braces
17 replies to this topic
  • PMAUST
Posted February 05, 2001 - 07:11 PM
Need advice. I have Acerbis Hand guards. I need additional braces to keep them from getting pushed in or moved around after a fall. I would prefer not to chop my clutch or break lever if possible. What are some good brace options? Thanks, Paul M.
  • Hick
Posted February 06, 2001 - 07:41 AM
I don’t know if these will work with Acerbis, but top clamp mounts would solve your problems:
GYT-R “guards” portion of site.
  • jj
Posted February 06, 2001 - 02:18 PM
Hey,
I've been posting about this exact issue for quite awile. I really want to mount my Pro Rally's to my triple clamp.
Cyrca and Yamaha among others make mounts but I'm unsure which if any work. If anyone has more info PLEASE LET ME KNOW!
I did found out today Yamaha doesn't have these mounts available yet.
I've called Mike from Flatland Racing about possibly making some mounts, I was told he'd look into it.
If any of you guys, or your friends, have experience designing...
Remmember the existing mounts don't allow you to pick which angle you want your guards to sit.
JJ
  • Hick
Posted February 06, 2001 - 02:25 PM
I have a set of Cycra top-clamp mounts that are almost identical (800-770-2259).
  • SFO
Posted February 06, 2001 - 04:41 PM
If you buy the pro taper top triple clamp it has the pinch bolts in the front.
I just ran a longer fastener and attached the inner portion of the hand gaurd to the top triple clamp bolt.
No mount and super clean...
  • PMAUST
Posted February 06, 2001 - 08:15 PM
I did go out to the Cycra online catalog to check theirs out. It sort of indicates that you would need to use their guards and the plastic covers are sold separately. If I can't get the Acerbis to work I may consider that route. I did look at the Yamaha clamp but not sure if that will work with the Acerbis guards either(don't like the looks of the yamaha guards). I also checked the Acerbis catalog but did not see anything there. I would prefer not to have to buy a top triple clamp just yet if I can avoid it. And JJ's point about not being able to adjust the angle is a good one. Although I can live with that restriction in order to get the added support. JJ let me know what you find out about getting some fabricated. Meanwhile, I try to get more info on the yamaha braces.
  • jj
Posted February 06, 2001 - 10:29 PM
I'll be sure to let everyone know if I can get something made.
Hey Hick, you have the Cyrca mount, does that mean you use them with the Cycra guards. Do you know if they'll work with the Pro Rally Guards?
JJ
  • Guest_Guest_*
Posted February 07, 2001 - 06:37 AM
I too have the Acerbis Rally Pro hand guards. My problem is the guide for the front brake cable mounts to the top clamp getting in the way of the guard, so I can't cut my bars down. The top clamp mounts look like a good idea but will they work with Acerbis and how do you run your brake line?
  • Hick
Posted February 07, 2001 - 07:53 AM
Guys,
I have Pro Bends mounted on Twinwalls and the clamp mounts solved a few problems at the same time. Pro Taper-sized mounts were still too small, and on my old 7/8” bars the guard and brake line interfered w/ ea. other (I like my levers WAY down for some reason). The clamp mounts will obviously work regardless of bar size and there is more space for the brake line.
I’m sure the clamp mounts will work with all normal bark busters like EE, Fredette, Moose etc. and I’ve had them on the stock Yamaha and Scott’s top triple clamps.
I used to have a set of Rally Pro guards, which I broke, and I can’t remember exactly where the inner mount was placed. I think if they are as long as ordinary bark busters the clamp mount will work, but they may be too short.
Bigger Picture
They look like they MAY work. Its too bad that these things (either Cycra or GYT-R), like everything else, are so *&%@# expensive or it would be easier to stomach buying a set to try them out.
  • Hick
Posted February 07, 2001 - 09:20 AM
JJ,
Some guy posted to this topic on DRN and said they did work in response to what looks to be your question (JJ, JAJ… Hey I’m Dick F*&%$# Tracy!).
  • jj
Posted February 07, 2001 - 06:11 PM
It's OK Hick, I completely forgot to check my post!
I posted another question, asking whether or not the mount allowed the guards to hang low. I, like many people ride with my levers low and am concered about coverage.
We'll see!!
[This message has been edited by JJ (edited 02-07-2001).]
  • SFO
Posted February 08, 2001 - 06:32 PM
I run the frt brk cbl behind the light cowl with a guide I fabbed up out of delrin.
Or I just run the yz plate for racing...
  • PMAUST
Posted February 08, 2001 - 08:51 PM
My Yamaha dealer said that he could get the triple clamp mounts. He also said he thinks they will work with the Acerbis bark busters. I am going in tomorrow to order them. Will let you all know how they work out. Paul
  • Eric_in_WA
Posted February 09, 2001 - 11:43 AM
I was very annoyed with the "rotation upon impact" feature of the Acerbis handguards. To remedy it, I made some brackets out of 3/32" Stianless steel flatstock. I bent, cut and drilled the stainless to make a small short bracket, which I bolted to top triple clamp The inside end of the handguard was bolted to the bracket. Much improved :)
Eric in WA
  • MoToHed
Posted February 09, 2001 - 05:43 PM
Go to www.srcinc.net Its scott summers stuf. You can't get any more burly.
  • RAZOR
Posted February 12, 2001 - 10:55 PM
If your interested, Yamaha makes adjustable handguard brackets. I installed them saturday afternoon, in about thirty-five minutes, and they look great.
The YAMMY part# is: GYT-5BE54-40-MT
cost is: $52.95 plus tax
I hope this helps-
RAZOR
  • jj
Posted February 13, 2001 - 07:30 AM
Razor, thanks for your reply. It looks like the # you gave is the mount pictured above.
You said that they are adjustable. Are you able to adjust the angle at which the guards hang? Can you explain?
Much appreciated!
JJ - 99 WR; WR timed, EKN Needle, Scotts stabalizer, Scotts triple clamps, Pro-Tapers, Michelin S-12's, Terry Cable hot start, MSR Raptor clutch lever, Moose skid plate, Works frame guards, Acerbis Pro Rally guards, Renthal MD-soft grips, Factory Effex graphics, YZ IMS seat base, YZ Factory Effex seat foam and gripper seat cover, YZ rear fender
  • RAZOR
Posted February 13, 2001 - 08:28 AM
JJ- They are adjustable for height and width of bars. Mine are angled slightly downward. If you like your levers way down you may have to bend the guard a little.
The woods style plastic shields are large and provide good coverage. If you have aluminium wrap-around guards, you should order these GYT-R brackets and give them a look. If they don't fit, Yamaha will take them back. Good Luck
RAZOR
