450 Engine in 400 Frame?
3 replies to this topic
  • chambers
Posted May 24, 2008 - 10:05 AM
Would a 450 engine fit in a 400 frame with no problems or would it be mroe of a chew on than its worth?
  • Frostbite
Posted May 24, 2008 - 10:21 AM
The mounts of an aluminum frame 450 are quite different, especially on top. The engine may physically fit in the frame, but I'd say there'd be a bit of fabrication required for the mounting brackets.
  • chambers
Posted May 24, 2008 - 11:57 AM
this is the one I am looking at
http://cgi.ebay.co.u...bayphotohosting
looks like the same tubular steel frame thats on the 400? If it is the tubular frame should that just be okay?
  • off_road_4_me
Posted May 24, 2008 - 07:26 PM
I dont think it would be a direct swap, and youd have to use the 450 engine from a 06 or older I believe
how good are you with a welder is the question though, because I can guarntee there would be modifications needed for mounts and such.
