2006 - A bit Vibey?
6 replies to this topic
  • thedktor
Posted May 23, 2008 - 02:32 AM
I have a brand new 2006 WR450 (steel frame, renthal bars) and just running it in.
It quite vibey at lower revs and then smoothes out at med revs, say 40+ mph in 5th.
Is this normal, will it get smoother as it beds in, are my Acerbis re-inforced barkbusters making it worse? (normally they help to reduce the bar vibes?)
Thanks ....
TD
  • Just_a_trail_rider
Posted May 23, 2008 - 03:54 PM
I have an 05, which is the same as 06 (except the enduro computer). Mine does not vibrate. Check your jetting.
  • JSanfilippo
Posted May 23, 2008 - 06:13 PM
Wait are you trying to ride the bike under 40 mph in 5th gear? 5th is way too tall for that.
  • swede426
Posted May 23, 2008 - 07:40 PM
Yes, then it's your chain making that noise.
  • thedktor
Posted May 24, 2008 - 01:41 AM
Its nothing to do with the chain - its engine vibes that show when stationary, in first gear, whenever. Not so noticeable off-road admittedly.
Just seems strange when the engine stays pretty smooth at 70+.
TD
  • davidwaters
Posted May 25, 2008 - 04:32 AM
Mine vibrates more than I'd like it to, but I figured it was normal for a thumper. Grips/gloves/etc might actually make a big difference on how much you feel and how much it bothers you.
  • thedktor
Posted March 17, 2009 - 10:30 PM
An old thread but was out yesterday and the vibes were quite annoying at times, I get a buzz through the bars at low/med revs, and a buzz through the pegs on the road.
Its really road use which shows it most, you get vibes on different part of the bike depending on the revs.
I would like to reduce the vibration on the left grip as that is the worst, and it can make the clutch lever buzz as well, any ideas ????? !
BTW, nothing is loose or about to explode, its just “normal” vibration.
Steve
