acerbis front disk gaurd
4 replies to this topic
  • wartsnuff
Posted May 22, 2008 - 05:46 PM
hey guys,
I just got a front disk guard, its easy enough to install
i have a 08 wr450
my question is when you take out the spacer it has the dust boot ? how do you get the dust boot off the spacer ?
or do you not, and just go with the seal now?
cheers
Warts
  • SXP
Posted May 22, 2008 - 05:50 PM
hey guys,
i have a 08 wr450
cheers
Warts
It pulls right off. The mounting bracket for the Acerbis guard has a spacer built into it which presses into the dust boot. I wouldn't ride the bike without the boot.
  • wartsnuff
Posted May 22, 2008 - 08:03 PM
for sure,
i just can't get it off thats all.
  • SXP
Posted May 22, 2008 - 08:54 PM
for sure,
My bad!! I just went out and checked my bike - I've mounted it up without the stock dust boot/spacer combo. The new spacer is pressed in through the grease seal protecting the bearing. It's been a while since I mounted the guard and I remembered the new spacer going through something protective - turns out it was the grease seal. I Apologize for the mis-information. FWIW, it's been holding up fine so far.
  • wartsnuff
Posted May 23, 2008 - 05:47 AM
ok,
i was going to say, this morning i got the dust cover off... but its grooved and does not fit the disk cover.
here is a pic of the bearing preload sleeve and the dust cover, notice the goove.
Here is a pic of the Acerbis disk protector. the land is far to big for the dust cover to fit.
thanks for taking the time to relook at your bike!
cheers
Warts
