oil in the ignition cover
3 replies to this topic
  • tetondrtbag
Posted May 21, 2008 - 07:38 PM
i went to check my valves today and when i pulled the crank plug on the ignition cover , oil came out. a lot of oil. any ideas why?
thanks,
MD
  • 642MX
Posted May 21, 2008 - 07:42 PM
thanks,
MD
Its normal. :thumbsup:
Posted May 21, 2008 - 07:48 PM
The main reason why is that that's the crankcase, and oil belongs there. The probable reason there was so much of it is that you hadn't run the engine in a while (your bike is most likely an '05 or earlier steel framed model, too).
Unlike two strokes, the actual central part of the crankcase is not a part of the intake tract, and needs no main bearing seals when it shares oil with the trans as the YZF does, and wouldn't need a seal on the ignition side anyway.
As to why there would be more oil after it stands for a time, read:
http://www.thumperta...903#post5221903
  • tetondrtbag
Posted May 21, 2008 - 07:56 PM
thanks!
  • Hot  36 replies
  • On January 15, 2017
  • 0 replies
  • Hot  50 replies
