ktmsx125 engine bolt torque specs
5 replies to this topic
  • sidevalve
Posted May 20, 2008 - 05:52 PM
hey anyone have a factory service manuel for a 99-o6 sx125 . Would you be kind enough to share some torgue specs .If you can help me out , i would be most thankfull .
  • Mike in Fresno
Posted May 21, 2008 - 05:26 AM
I have a 200 manual, I can give you torque for that and they are basically the same
  • sidevalve
Posted May 22, 2008 - 06:55 PM
Thanks mike that's awesome . What I need to know are the torgue values for the: clutch hub nut , cylinder bolts , head bolts , mag nut , crank main gear nut . if you could come up with those for me that would be awesome . I could barely afford the rebuild parts , much less the manual . Been laid off since january . Thank-you
  • Mike in Fresno
Posted May 23, 2008 - 06:13 PM
Ive got the book out, NM or Lbs?
  • sidevalve
Posted May 24, 2008 - 07:27 AM
hey mike , thanks for getting back to me . foot pounds , inch pounds , it's all good . I can convert if I have to . thanks
  • Mike in Fresno
Posted May 24, 2008 - 07:40 AM
clutchhub 74f, head and cyl 25f, flywheel 44f, primary gear LH thread 110f
