07 wr450 oil change amount?
16 replies to this topic
  • mikeythefokker
Posted May 19, 2008 - 09:14 AM
Hey guys, I was just wondering how much oil you guys put in you 07/08 wr450's. Whenever I put a whole quart in, the thing pisses out oil from the breather in the air box. ***. I have been using about 80% of a quart for a month now, but I don't know if that's right. Any help would be appreciated. 07/08's only though, the 06 and older have a different setup.
  • atitagain
Posted May 19, 2008 - 09:19 AM
Are you opening both drain plugs and taking out the dipstick to vent the case while draining? I found out the hard way that it likes to be vented. After that...it takes just what the manual specifies.
  • taycam
Posted May 19, 2008 - 09:27 AM
and make sure to stand bike upright to drain both sides. Note: 07 - 08 are different from the older models
  • SJMC_DON
Posted May 19, 2008 - 09:59 AM
+1... :thumbsup:
  • AK-Bandit
Posted May 19, 2008 - 01:40 PM
Just changed the oil on my '07 this weekend. It required exactly what the manual stated. I remove the fill cap, dipstick cap, both drain bolts, and the oil filter cover. I usually lean my bike from side to side to get as much old oil out as possible.
Are you replacing your oil filter every oil change? If not, it wont require as much oil.
  • b13
Posted May 20, 2008 - 03:01 AM
From the manual for a wrf 250 2007:
periodic oil change 1.1 litre (0.97 imp. qt, 1.16 US qt)
with oil filter replacement 1.2 litre (1.06 imp. qt. 1.27 US qt)
Hope this helps.
  • idamoh
Posted May 20, 2008 - 07:49 AM
I have a stupid question maybe someone can answer. I just bought an 08 wr450 also and they tell me to use the yamalube oil. Why can't I use the old 10w40 you get a pep boys or autozone? I remember as a kid using the same oil in my bike as my dad did in his truck.
  • swede426
Posted May 20, 2008 - 08:24 AM
The only stupid thing is to not ask and go around in some bubble believing you know everything:thumbsup:
This is copied from my wr426 manual:
"""(For USA and CDN)
At 5 °C (40 °F) or higher
Yamalube 4 (20W-40) or SAE 20W-40 type SH
motor oil (Non-Friction modified)
At 15 °C (60 °F) or lower
õ
Yamalube 4 (10W-30) or SAE 10W-30 type SH
motor oil (Non-Friction modified) and/or
Yamalube 4-R (15W-50) (Non-Friction modified)
(Except for USA and CDN)
API “SH” or higher grade"""
I guess it's only your dealer that wants to squeeze some extra $$ from you but you make your own choice what to put in there.
I myself runs Texacos motex 4t-X 10W-40(non friction modified).
Worked good for me and I think you can run whatever you want and like, as long as the specs are same or better than manual says, and very important,-change often and it will turn out OK.
  • cjimenRR
Posted May 20, 2008 - 01:18 PM
Your clutch plates will not like the energy conserving oil type used in motor vehicles, you may not feel any immediate problems but down the line is a diffrent story.
  • redswr
Posted May 20, 2008 - 01:42 PM
same thing happend to me the first time i changed the oil... i forgot that there are 2 drain plugs one one the left and one on the right.
  • C-P
Posted May 21, 2008 - 08:45 PM
Generally, most if not all automotive oils have friction modifiers...bad for wet clutches in bikes. There's lots of other bike oil out there that's going to be the same or better than yamalube. They're probably just relabeling someone else's oil anyway...
  • 1991cbr600f2
Posted May 21, 2008 - 09:28 PM
+1 and amount of oil was exactly as my 07 450 manual stated.
I wish the process was like the old days, 1 drain plug and a dipstick on the filler, but I like the new bike power, so fair trade I guess.
  • vtripper
Posted August 22, 2009 - 04:21 AM
I have the same problem. I drain both plugs, oil filter, take off oil dipstick, open oil fill and lean bike from side to side. I only get just shy of a litre out. What the heck is going on?
  • Yamaha_James
Posted August 22, 2009 - 04:24 PM
Are you runing the bike for like 5 minutes before draining? That is what the manuel for the TT-R says to do, that might help.
  • thatraptorguy
Posted August 22, 2009 - 04:29 PM
ya its good to get the bike warmed up first because then the viscosity of the oil is alot thinner and will drain out much faster and you'll get more out.just watch when you pull out the drain plug you dont get the oil on your hands because itll be pretty toasty
  • vtripper
Posted August 23, 2009 - 02:09 AM
yes I allway's run the bike before an oil change, next time i am going to tip the bike not only from side to side but put the bike up in the front than up in the back.
  • Yamaha_James
Posted August 23, 2009 - 10:33 AM
Thats what I thought, I just didn't know if it was different for a dry sump bike. :ride:
