YEAH, I finally figured it out.
10 replies to this topic
  • Coastie3202
Posted May 19, 2008 - 07:32 AM
I am so happy. I finally figured out the setup for my YZ 450F. Now I feel faster, smoother, and I am not getting beat to death. Now I can really appreciate the capabilities of the 07 YZ 450F. Here's what I got:
Front and rear tire pressure: 8.5 lbs (riding in desert with lots of sand).
Rebound - went factory setting front and back
Compression - 10 out from hard, front and back
Sag - 3.5"
Stock Pro Taper bars with Tusk bar riser kit, all spacers installed except thinnest one.
I find that I am much faster sitting down. This setup allows that without jarring me when I hit sharp edges. I can get up off the seat very quick, and the bar height really helps to get the bike turned and loft the front end when needed.
  • StPeters21
Posted May 19, 2008 - 07:52 AM
i just did the same thing with the riser kit....wow...much better. I do get some high speed head shake. I haven't figured out the exact spacer set for me, but this is great. I'm a cornering fool now!!!
BTW, I'm 6'3" and left out one of the middle spacers. I might switch and try your set up
  • Coastie3202
Posted May 19, 2008 - 12:51 PM
I started fairly small, kept adding spacers, and finally hit it right on the head with the tallest setup (except for the thin one). Man what a difference. You are taller than me, you'll probably want all of the them installed.
  • StPeters21
Posted May 19, 2008 - 01:00 PM
I probably do...Just feels weird. Not used to something actually almost being comfortable....lol
  • FreshDonutsCAN
Posted May 20, 2008 - 06:04 AM
hey coastie how tall are you and your weight??
  • Wrong-Way
Posted May 20, 2008 - 08:06 AM
Rear sag at 4.0 Front Lower at 12, Front uppers at 11. Rear lower at 9, Rear upper at 14. Tire pressure at 9psi front and rear. Soft dirt and sand riding. Made a world of difference. I'm 5'9" at 170.
  • Coastie3202
Posted May 20, 2008 - 10:42 AM
6'2", 210 lbs with all my gear on.
  • Beaz
Posted May 22, 2008 - 11:56 AM
Sag - 3.5"
Where did you buy the riser kit at?
Im 6-2 220 and was thinking of trying a riser kit
  • Beaz
Posted May 27, 2008 - 03:32 PM
Anyone:excuseme:
  • Coastie3202
Posted May 27, 2008 - 04:45 PM
I bought my Tusk riser kit from Rocky Mountain ATV for $20.00. Best $20.00 you'll spend.
  • StPeters21
Posted May 28, 2008 - 05:47 AM
I 2nd Coastie3202!!!!! It helped my bike in several ways. From arm pump to cornering...Amazing. I never knew how important it was to make a bike fit you.
  • On January 15, 2017
  • Hot  36 replies
  • Hot  50 replies
  • Hot  47 replies
