Hi fellow trials guys and girls.
I picked up this bike last fall and I've tried nearly everything I can think of to cure this. Here's what the bike has done since the day I brought it home. When you hold the throttle steady at part throttle, the bike leans out, revs out of control and detonates horribly. For example, if I try to hold a steady speed at part throttle in 3rd or 4th gear it will do it. Wheelies are nearly impossible because of this problem.
The engine has great primary compression and will start on first or second kick.
Here's a list of what I've tried.
several spark plug styles and heat ranges.
Jetting. I've tried jet sizes and needle positions till the engine would choke on all the fuel. Still does it.
Fuel,, yes, even with race fuel it leans out at part throttle and deto's.
reeds,, brand new carbon fiber. still does it.
crank seals.. you guessed it, brand spankin new.
muffler, cut apart and repacked.. same thing.
I've had the cylinder and piston off. All well within tolerance and cleaned.
screen in delorto, clean.
screen in tank, clean.
fuel tank is vented properly.
float level raised as far as possible and still leans out at part throttle.
spark timing. yup, monkeyed with that too.
Slide cutaway, temporarily altered to increase velocity at low and mid range.
The squish band is .040 at its narrowest point. Thinking of narrowing that to .030.
:banghead:
I'm stuck with this bike for a while so I hope someone out there has an answer.
