My conversion...
12 replies to this topic
  • ixxe65
Posted May 18, 2008 - 09:33 AM
I finaly finish my new conversion... first I want to thanks everyone who post their conversion and knowelge on TT... without you I donk think I will ever try to made mine... thanks alot... so... it took about a mount to complete it... now I need some good weather to test and fine tuning it... to make a short story I wanted to make it last year but I did not have the time and all the parts it need... so I refresh my 1997 cr80 to have a ride for the moment... now... I have the time and all the parts that it needs to start the project... so here a list of what I used and some pics too...
start with a 1997 cr 80 expert
2002 cr85 frame
1998 xr100 motor
BBR 120 bb kit
xl185 carb (22mm)
BBR pipe
2008 CRF 250r rear brake master
klx125 air boot
Cannon racecraft shock spring (5.8)
Cannon racecraft fork spring (.38) with 10 weight oil
2003 xr100 gas tank
I may need to update this list because it will be a work in progress bike...:thumbsup:
now some pics...
start on april 13
start with 1997 cr80 with 2002 cr85 frame
frame cut
test fit...
welding done...
rear motor mount...
I also painted the swing harm... I think it look better this way...
rear brake assembly and fitting...
now the rear under motor mount is weld and also the skid plate...
  • ixxe65
Posted May 18, 2008 - 09:34 AM
and the final result...
may 16...
and now the finish(almost... need new front wing and number plate...)
now it's time to go and ride it...:thumbsup:
  • gman255
Posted May 18, 2008 - 02:10 PM
Sweet! Nice job brother!:thumbsup:
I like what you did with the intake..
Did you use an existing one and slice it?
  • ixxe65
Posted May 18, 2008 - 04:16 PM
gman255... I used the stock xr intake and remove the rubber... after that I found some pieces of aluminum tubing and weld it to the flanges... look that this will do the job... will see in future if it will hold fine... thanks for your comment...
  • Bmo
Posted May 19, 2008 - 12:11 PM
You made that look easy, good job.
  • Kyron
Posted May 19, 2008 - 02:01 PM
Nice!
I like how you notched the brake pedal...... do you think it might need to be reinforced?
  • ixxe65
Posted May 22, 2008 - 04:42 PM
I dont think it need to de reinforced... this is the steel brake pedal and it was very strong even with the notch... the only problem that I have for now is that the brake pedal hit the footpeg when braking and I am not sataified with the braking power... I am looking for idea to resolv this... any idea someone...:thumbsup:
  • gman255
Posted May 22, 2008 - 05:32 PM
I'v bn thinking about making a brake pedal for mine.
Kinda like DMC's
  • johnk408
Posted May 23, 2008 - 05:25 AM
I thought you were making a chopper when I glanced at the picture of the frame under the motor mount picture. Then I realized the frame was upside down:bonk:
  • MOTODAVE63
Posted September 27, 2008 - 01:53 PM
nice job, i am also building a conversion, what bike did your intake come from (carb to airbox)?
  • zbnutcase
Posted September 28, 2008 - 09:04 AM
Sweet ride man! Nice metalwork on the frame!! 'nutcase
  • ixxe65
Posted October 01, 2008 - 03:31 PM
Thanks guys...
The boot from the carb to the air box came from a KLX125... work great... if you search on this forum you will find some good post about that...
  • xr4_rider
Posted October 01, 2008 - 06:10 PM
Nice job!
I hope it was a fun build.
See my converson here http://www.thumperta...ghlight=crf150r
93 honda xr100r by Honda fanatic
Dirt Bike   Make / Model Specific   Honda   XR/CRF 80-200
  • Hot  84 replies
xl100s vs xr100 trans difference? by CarmanCRF
2002 XR200R Won't start by t_corn
  • 3 replies
CR 230F Making it Street Legal with the best Speedometer by crfer2
  • Hot  35 replies
  • Hot  36 replies
