Best Cylinder Hone???????
9 replies to this topic
  • ToolBoy
Posted May 18, 2008 - 04:59 AM
Gday Guys,
I want to clean up the Cylinder on my RM 400 N....which is the best type of Cylinder Hone to use??????
Thanks
Toolboy
  • pwrpapa
Posted May 18, 2008 - 05:15 AM
Any ball hone will work. Really all you have to do is take a scotch brite pad to it to remove the glaze.
  • pb_paulie_b
Posted May 18, 2008 - 09:46 AM
A ball hone is tops. Don't use a cheapo hone with the 3 arms and stones on a 2 stroke. The stones get caught up on the ports.
  • Kev_XR
Posted May 18, 2008 - 12:10 PM
Do the 3 blade arm hones work well on 4-stroke cylinders?
Or are ball hones the way to go always?
  • pb_paulie_b
Posted May 18, 2008 - 01:05 PM
They are fine for 4 strokes. IMO the ball hone is still the better way to go. One advantage of the 3 stone design ones is their available at any auto parts store.
  • speedy81304
Posted May 18, 2008 - 07:15 PM
the ball hone if used correct will hone in a nice cross hatch patern at a 45 deg. this is the best hone job you could do. those three arm hones dont cross hatch cylinders they just take the glaze off. if i was building an engine and wanted it to break in correctly i would go with the ball hone. if i was throwing an engine together just for a weekend of drag racing then a quick three arm hone i would use. but on 2-strokes a ball hone no matter what our your asking for port damage
  • ToolBoy
Posted May 19, 2008 - 05:45 AM
Do i need to buy the exact size hone????
Bore size is 82mm....mmmm 3.22 inches
Can i use a 3.5 or 4 inch hone?????
Thanks for the great info
Toolboy
  • zbnutcase
Posted May 19, 2008 - 07:43 AM
There is no exact size ball hone, they are sold by size range. Just buy one in the size range your cylinder falls in. The 3.5in should be fine. 'nutcase
  • Matt James
Posted May 19, 2008 - 08:53 PM
If you want it right, you should never use a berry hone on a two cycle. The balls fall into the ports and erode the edges of your cylinder at the ports. It causes sealing issues. A sizing hone is the best. Any auto machine shop will do it.
  • resurrection
Posted May 21, 2008 - 08:34 PM
Sunnen brand hones the three arm rachet type we use .the rite stuff but very$$
Ball hone is affordable at garage level and better for less ex.user as the three arm Sunnen will remove to much stock . Although it will be a straight oversize hole.
