Is this a stock 99 WR400 carb?
6 replies to this topic
  • chickenstrips
Posted May 17, 2008 - 10:44 PM
1999 WR400F
I bought the bike used and was not told anything about the carb being changed out, but from what I've seen it doesn't appear to be stock (no linkage cover?).
I need to know if it is stock or something like a FCR41 so I can order a few parts for it.
Need float bowl o-ring gasket, intake bell o-ring gasket, accel pump diaphragm and o-rings (may be a good time to go to a larger AP?).
Anything else I should consider replacing? The wheels on the arm that pulls up the slide looked a bit worn, but nothing else looked bad.
I also wrote down all the jet sizes and needle type for looking at after I figure out which model of carb it is.
Pictures:
Does that hole need to be plugged or anything?
Thanks.
  • LiveSideways
Posted May 18, 2008 - 02:16 AM
Stock Keihin FCR 39
  • Birdy426
Posted May 18, 2008 - 10:35 AM
Stock except for the Power Now (Gold colored intake bell that replaced the stock plastic piece. It has a "wing" in it to increase air flow velocity at part throttle settings.
  • chickenstrips
Posted May 18, 2008 - 12:05 PM
Cool Thanks, i will order up some parts for it. Is the stock A.P. sufficient? I will just order a new diaphragm for it.
  • D-Z
Posted July 23, 2009 - 11:11 PM
i noe this is an old thread, but i need help!!ive got the same carb fcr3 41 on my wr400..but mine boggs all through the mid and top end, and backfires like a machine gun.. ive already did send it to my mechanic but seems he is unable to fine tune the carb..wats the jetting like? i have a FMF powerbomb header and whitebrothers e2 exhaust and the bike is on YZ timing..
any help appreciated please!!
  • gtcodave
Posted June 20, 2013 - 02:59 PM
correct me if i'm wrong and i know this thread is a bit of an archive but didn't the WR400F have a 39mm bore carb?
Posted June 20, 2013 - 03:11 PM
Yes it did.
Once the old FCR's get worn and tired, the best thing to do with them is replace them with an FCR-MX from a later model. The '05 and up YZ450 carbs are an excellent choice.
You would need the 450 cables, and the complete hot start assembly as well.
