Wide tire vs. muffler
9 replies to this topic
  • TWILES
Posted May 17, 2008 - 06:50 PM
How wide of a rear tire can you go before it scrubs the muffler? 110-100 is stock. 120-90 and 130-80 are right at the same hight tire but one is 10mm wider and the other is 20mm wider.
  • JSanfilippo
Posted May 17, 2008 - 08:00 PM
You should be able to run a 120 w/o any probs
  • maxtherat
Posted May 17, 2008 - 08:09 PM
120/100. No problems for me.
  • tweav
Posted May 17, 2008 - 09:45 PM
I had a 150 on the back of mine it just hit so I shimmed the pipe out. I'm running a 160 right now it hits I need to do a little reworking on my pipe to make it clear now . I can't see that a 130 knobbie would hit . I have a 130 knobbie on my crf250x it clears fine
  • mikeythefokker
Posted May 18, 2008 - 12:41 AM
How do you guys like those big tires? I have always run the 110's and 100's and they have felt nice and nimble when cornering. Do the big tires get clunky or heavy?
  • TWILES
Posted May 18, 2008 - 08:33 AM
I'm wanting to go wider hoping it will corner better. There's no "railing corners" in Kentucky unless you are on a track. Where I ride, it will go from mud to pretty much concrete. The more knob on the ground, the better.
Thanks for the input everybody.:thumbsup:
  • MountainMax
Posted May 18, 2008 - 03:54 PM
are those wide tires you guys running any taller? im very tall and want the tallest tire i can get, im running a 120/100 now, taller then stock 110/100
  • TWILES
Posted May 19, 2008 - 08:29 AM
The way you size the tire is mm wide/% of width off the rim/wheel size.
a 110/100/18 is 110 mm wide/110 mm off the rim/18 inch rim
A 120/100/18 is 120mm off the rim to the top if the tire. It will set you 10mm higher.
  • MountainMax
Posted May 19, 2008 - 08:50 AM
lol, i know how tires are measured, but thanks for explaining it, however those guys said they were running 150 and 160's never said if they were /100% 's or what so i wasn't sure, could have been /80% tires too and they wold not be any higher then. and i heard some tires are measured differently in europe then here in North America also.
  • tblrk2008
Posted May 19, 2008 - 08:57 AM
What about the chain hitting the tire side......kinda like what happens with the supermoto setups
