Resurfacing Cylinder Head
2 replies to this topic
  • hazey123
Posted May 17, 2008 - 03:28 PM
Quick question on resurfacing cylinder head. I am having trouble removing the bolts that are threaded into the cylinder head. Do I just clamp in the middle with some vise grips and wrench them off? Are the threads reverse in the head? Is there a trick to it, this is my first time doing this. I need to get these bolts out before I can even start sanding the head.:thumbsup: Thanks
  • usmcpaul
Posted May 17, 2008 - 05:00 PM
Are you talking about the head bolts or alignment dowels/pins?
And are you going to sand the head by hand?
  • bustersat
Posted May 17, 2008 - 05:32 PM
use two nuts that fit the threads. Jam them together, then turn the one closest to the head counter clock wise. should come right out. if not try just a little heat to loosen them.
  • 10 replies
  • Hot  47 replies
  • 9 replies
  • Hot  50 replies
Motocross
  • Hot  491 replies
