Removing a WR 450 flywheel
4 replies to this topic
  • Carl_Mega
Posted May 16, 2008 - 09:36 AM
I need to check my starter clutch but I'm having a hard time removing the flywheel. The only tool I found to do it is a Motion Pro that costs $40!:thumbsup: (MP 08-0390).
Is there a garage method to get this off? I really don't want to spend $$ on a tool I'll use once.
Thanks.
  • SJMC_DON
Posted May 16, 2008 - 11:04 AM
I need to check my starter clutch but I'm having a hard time removing the flywheel. The only tool I found to do it is a Motion Pro that costs $40!:rolleyes: (MP 08-0390).
Thanks.
What year is your bike?
I just paid $57 for another brand, it's 33mm x 1.5 RH thread... this worked on my 07. I don't think you want to use any other method, flywheels are probably a lot more to replace than the investment into a puller...:thumbsup:
  • Carl_Mega
Posted May 16, 2008 - 11:14 AM
Thanks for the reply.
I found a tool from TrailTech for $20 (click link for item description).
That's a bit more palatable.
It's a 2004.
  • SJMC_DON
Posted May 16, 2008 - 11:35 AM
When you know the size and thread pitch on the puller can you post it? I am still not convinced that the 07's are different from other years and want to know if I got hosed or not, not that it will replace the $57 into my bank account but live and learn is my motto when working on this bike.:rolleyes:
Good luck!
You should invest in a timing chain ($12) if you are going to have the flywheel off... you can adjust valves as needed at the same time :thumbsup: It's a little more work but on 2004 it would be cheap insurance if, like I said you are going to have the flywheel off.
Best of luck:ride:
  • Carl_Mega
Posted May 16, 2008 - 11:54 AM
MotionProTool
This tool's description says it's a 33X1.5 from 04-06.
However, the bikeMaster tool says it's 30MM. I don't think that's right. The woman at the motoshop checked to see if it was a misprint and it apparently is...that's the wr250 tool.
